Results of putting airbox back on
  • larrycavan
  • larrycavan's Avatar
Re: Results of putting airbox back on
26 Feb 2011 10:36
#433547
Some might be surprised just how much you can tape up a set of pods without affecting the engine, even at the drag strip.
There are a lot of variables that play into the mix but all things considered, I'm absolutely convinced that for best all around performance, a still air chamber provides the carburetors with the environment they like best.
If you can make it's volume adequate to feed the size of the motor's demand at it's peak HP RPM, you'll find the bike just flat out behaves better everywhere.
If someone sends me a complete KZ1000 airbox they don't need for a while, when I get some free time, I'll do some flow tests on it. In all these years, I've never tested a stock airbox. I'd kind of like to know myself just how big of a motor it could feed ;)
  • Old Man Rock
  • Old Man Rock's Avatar
26 Feb 2011 10:43
#433548
"KZ1000 airbox they don't need for a while,"....
Now you freaking tell me.... :laugh:
Matter of fact I do.... The 1000 came with an air box but the nipples are broken off... easy remedy to repair I believe...
That work for ya?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • fordtruck
  • fordtruck's Avatar Topic Author
26 Feb 2011 14:19
#433582
OMR,
The carbs are 1980ish VM28s. Head was rebuilt and ported by Pit Stop. New guides, seals, APE HD valve springs, and 3 angle valve job. Pods are used K&N's that I bought off of Ebay. I bought them because they are marked as Vance and Hines where it normally says K&N. Look to be in good shape. I'm running the stock cams. I was going to change the cams, but I'm pretty happy with the way it runs now. Someday I will want more power. The head is already clearanced for larger cams.
'77 KZ1000-MTC 1075 kit. Stage 1 port
  • Old Man Rock
26 Feb 2011 16:58
#433612
Just of of curiosity, had you changed your needle size for the pods?
Based on "I couldn't get rid of the surging while cruising down the highway".... first thought would be running lean... I'm sure you had tried various needle clip positions with less then ideal results...
Example, if at max clip position and surge still present, then needle change would be the first thing to do....
Doesn't really matter now where air box back on and you're back to no surge... Excellent, objective met... right on.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • fordtruck
26 Feb 2011 17:39
#433619
OMR,
I tried shimming the stock, nonadjustable needles. That didn't work. I then put in the adjustable needles out of my original vm26 carbs. I set them full rich. That helped but didn't cure it. I could almost cure the surging by tweaking the airscrews. But, that made the idle so rich that it would foul the plugs. Maybe different needles would have fixed it. Honestly I flat out got tired of pulling carbs! Like you said it really doesn't matter since its running good now.
  • larrycavan
27 Feb 2011 05:04 - 27 Feb 2011 05:07
#433667
Had you started with a brand new rack of CRS29 carbs, you would have had much better results and most likely never even have given the airbox a second glance.
Last edit: 27 Feb 2011 05:07 by larrycavan.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
27 Feb 2011 06:38
#433684
+1 :)
and I'd love to see that data!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • enaz1
  • enaz1's Avatar
27 Feb 2011 07:13
#433691
+2 ditto:)
75 z1 900 Big Guy
  • Old Man Rock
27 Feb 2011 07:25
#433694
Already spoke to Larry... I need to order some new Air box hoses (Z1) from Jeff and repair the broken barb fittings then off to him for CFM measurements and such...
Will be a week or two before I get it out to him....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • fordtruck
27 Feb 2011 08:57
#433714
I'm sure that you are right. But, I got these VM28 carbs for a great price. I didn't have the money for new carbs after rebuilding the motor. Plus I learned a lot about how carbs worked over the last year!
When I get bored with my newfound power I will put cams and new carbs on it. That should give a nice boost to what is already a very stout motor.
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
27 Feb 2011 23:43
#433911
B)
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • larrycavan
28 Feb 2011 03:52
#433919
It's hard when you're working with limited funds and old parts. You've done a good job with it. It's like the cake is baked and the icing has yet to go on.... When it does...you'll enjoy every bite :)
