Results of putting airbox back on
  • fordtruck
  • fordtruck's Avatar Topic Author
23 Feb 2011 23:05
#433056
I took off my factory airbox and went with K&N air pods when I rebuilt my motor. I had the head ported and installed 1075 10.5:1 MTC pistons. Every since then I have hated the pods. I couldn't get rid of the surging while cruising down the highway. I wanted to put the airbox back on but I was afraid I would lose power.
Boy was I wrong! Not only did it eliminate all of the surging, it seems to have more torque now. From 20 MPH in first it will spin the rear tire all the way to redline if I pin the throttle. It doesn't seem to have lost anything on top. I really wish I had never taken the airbox out in the first place.
'77 KZ1000-MTC 1075 kit. Stage 1 port
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Results of putting airbox back on
23 Feb 2011 23:46
#433058
Yep...those were clever Kawasaki engineers...I'm running pods on my KZ1000A1, but only because the airbox is rare :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
24 Feb 2011 00:50
#433063
It's awesome to hear someone sing the benefits of an airbox- much less the stock airbox! I've been hesitant to switch to pods, and the more I read on here, the most likely I'll keep my airbox.
Kudos to you, sir!!!
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
24 Feb 2011 07:32
#433101
It depends on your experience and expertise in tuning carbs, wether or not a set of pod filters will work.
They are terribly finicky, and generally result in the mixture screw settings being quite a ways off from eachother once setup correctly.
Yes, they will tend to not produce as much torque until full advance, but will make lots of extra power in the mid-high range, especially at high speed - IF tuned correctly.
You got all your power back cause your bike was too lean and the airbox smoothed things out, closer to corrrect accelleration mixtures. It is possible with pods, but difficult to duplicate.
Cheers.
I run my 791000 with pods, and my 81 1000csr with airbox.
Both tuned well, the csr can leave the line faster than the 79 and carry 2up well, but i cant do anything to catch the 79 after 6000rpm, or top it on the highway.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • PLUMMEN
  • PLUMMEN's Avatar
24 Feb 2011 07:35
#433103
its those wonderfull bs34s on your csr! :woohoo:
gearing is probably differant also B)
  • fordtruck
24 Feb 2011 08:38
#433114
Cheers.
B)
Well said. Someone with more experience tuning carbs might have been able to get it to work better. I did notice the air screws were very different from each other. After putting the airbox in, they are all within a quarter turn of each other.
I don't spend much time at high speed, so a little loss on the high end is worth it to me. I also like not having to worry about getting caught in the rain. I had that happen once with the air pods and it made it run crappy until the filters dried.
  • TeK9iNe
  • TeK9iNe's Avatar
24 Feb 2011 08:42
#433115
:laugh: Yeah.
... and the gearing is different on both.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • bountyhunter
  • bountyhunter's Avatar
24 Feb 2011 11:14
#433129
fordtruck wrote:
I took off my factory airbox and went with K&N air pods when I rebuilt my motor. //// I couldn't get rid of the surging while cruising down the highway. I wanted to put the airbox back on but I was afraid I would lose power.
I nominate this to be a sticky......:laugh:
  • PLUMMEN
  • PLUMMEN's Avatar
24 Feb 2011 11:52
#433136
how many busas do ya see running pods? :laugh:
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
24 Feb 2011 12:26
#433141
None, but aren't those a ram air setup surrounded by plastic bodywork buried under the gas tank?
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • PLUMMEN
  • PLUMMEN's Avatar
24 Feb 2011 13:13 - 24 Feb 2011 13:21
#433146
the reason they say not to use them on sportbikes is it causes turbulance,stirs up the air on kzs also would be my guess. B)
Last edit: 24 Feb 2011 13:21 by PLUMMEN.
  • racer54
  • racer54's Avatar
24 Feb 2011 18:31
#433228
Take off the pods and mount a turbo. Only one carb to deal with and "turbo-lance" is a preferred affect! Ask Plummen!!!
