Anyone know mikuni rs carbs with pumper very well?
  • XTREMETOPGUN_30
  • XTREMETOPGUN_30's Avatar Topic Author
20 Feb 2011 13:14
#432144
Hey i have a 79 kz1000 ltd. Cone filters a 4 in 1 exhaust with short baffle. Any if i snap throttle i have a big hickup somethimes stalls if i hold it open. Took the first pumper screw out just to get the tab to touch pumper rod.Sometimes the rod touches tab sometimes there is about 1/16 th of a gap is this normal or should it always touch. If so do i need to replace pumper parts, or am i just being to picky? Thx for looking and any responce is greatly appreciated. ERIC
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Anyone know mikuni rs carbs with pumper very well?
21 Feb 2011 13:59
#432462
Not 100% certain, but I believe they should always touch. The bike should rev fine with the pumper working right.
I would remove carbs and rebuild the pumper with an appropriate kit.
Were the carbs re-jetted and idle mixtures set after filters/exhaust was installed?
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • XTREMETOPGUN_30
21 Feb 2011 15:15
#432495
No rejetting yet i know i will at least the mains. I truely believe its the pumper at least right now.Thx again for any and all help.
  • DFIGPZ
  • DFIGPZ's Avatar
26 Feb 2011 16:02
#433597
leave accel pump alone. i have set many of these up and if you increase pump shot you are covering up another problem.
ex lean needle setting, low float setting etc.
1984 750 Turbo
  • hal0tw0
  • hal0tw0's Avatar
26 Feb 2011 16:21
#433600
Im going through my carbs right now and dealing with a hiccup/hesitation with my 79 vm28s on my 76 900. Im going to go into detail in my own post but basically its underjetted I betting.
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
  • kzr750r1
  • kzr750r1's Avatar
26 Feb 2011 16:38
#433605
Just to make sure what were talking about here...These are a new kit or some old stock from another bike?
Are you just cranking your throttle wide open from idle?
In my experience with the RS you needed to use way more control with throttle input as to not create a lean condition...Thus bog and lack o power. But when you get it right look out.
Now this is on a different bike all together. I did have some time with a dyno to get mixtures correct as possible with the given conditions.
There are others out here that have RS with similar bikes/displacement, hopefully they will pipe in.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
