87 kz305 running lean?
  • invisible4good
  • invisible4good's Avatar Topic Author
19 Feb 2011 12:16
#431839
ok picked up a 1987 kz305... cleaned the carbs, set the float heights, made sure the valve needle was working properly, and gave it fresh gas and oil. went to go start her up and she ran.... however the bike will bog when i give it half throttle... if i hold it at full throttle she wants to catch. the bike idles great when choke is open. we stuffed a shirt infront of the carb mouths and it revved up great! so i got a stock airbox and filter, but its still coughing and bogging at half throttle to WOT. any ideas? and where is the idle mix screw on this bike? thanks!
