Bench sync 29mm smoothies question?
  • lewisj
  • lewisj's Avatar Topic Author
16 Feb 2011 07:10
#431035
When bench syncing 29mm smoothbores I find two screws at the top of the slide. One is threaded with a locknut and the other is just a normal 8 or 10mm bolt. I know the adjuster will raise and lower the slide, however do I need to loosen the other bolt as well or leave it be?
thanks in advance!
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Bench sync 29mm smoothies question?
16 Feb 2011 14:47
#431109
Just open the top nut that is around the small adjuster screw. Then adjust, then re-tighten nut.
I like to bench sync using a piece of metal coat hanger. I adjust the slide up high, then slide the rod through the bore and tighten down the slide to the rod just gently. Then I turn the carb on its side and slowly loosen the adjuster until the rod falls out on its own, then tighten the adjuster nut.
Do the same for each and they will be dead bang on.
best luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • lewisj
16 Feb 2011 15:58
#431118
Thanks Tek9ine! I am off to the garage, wish me luck.
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
  • TeK9iNe
  • TeK9iNe's Avatar
16 Feb 2011 16:19
#431121
Jim
:laugh: Good luck, i'm sure you'll do fine.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
