can't find any rubber hoses
- 29 palms
06 Feb 2011 11:05
I recently started clean up my carbs (1981 kz650 csr)after rejetting. I'm going through trying to replace all the vacuum lines and fuel lines. I'm having trouble finding hose that is mall enough, and flexible enough for the carburettor drain hoses. I've been to a few auto stores, and local motorcycle shops but haven't had any luck. Where do you guys get all your hoses when you rebuild your carbs, I know you dont reuse them
Thanks
Thanks
1981 KZ650 cafe racer build
www.dotheton.com/forum/index.php?topic=21888.0
- MFolks
Re: can't find any rubber hoses
06 Feb 2011 11:11
Windshield washer hoses will work, if you don't mind the color of light blue,the flying model airplane guys have silicone tubing of many diameters.
- JMKZHI
06 Feb 2011 13:58
A lawn mower shop might have the needed size, but that might get a bit pricy.
How about a hardware store?
- loudhvx
06 Feb 2011 14:15
Home stores used to carry really small diameter urethane fuel line for lawn equipment. I've used them for drain lines and breather lines, but don't use them for fuel or vacuum. Fuel makes them brittle and crack, and they don't seal well enough for vacuum.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- PLUMMEN
06 Feb 2011 15:10
what Lou said
- gane
06 Feb 2011 15:29
If you have a "Polaris" dealer near you, stop in & ask... Their 4 wheelers & snowmobles use the same stuff, & sell by 25 ft roll. most places will sell by the ft. if not. aquarium shops will have the right size but doesn't last..G
[img][/img] 1977 KZ1000A1
- tooocool49723
06 Feb 2011 16:31
Home depot sells chainsaw fuel hose. Perfect size for my drain tubes!
'82 KZ550 "Project"
First bike, 30k miles
Ann Arbor, Mi
Ann Arbor, Mi
- JR
06 Feb 2011 18:04Windshield washer hoses will work
The stuff I use is black, comes in a 2M / about 6 feet pack and is gas and oil resistant. Lasts 2 -3 years.
I cant remember the diameter... thinking something like 5/32. Small enough so that I never need a hose clamp.
- TerryK
06 Feb 2011 19:04
A local shop a friend owns has primer hose that is the perfect size for overflow lines. The nice thing is that it comes in a couple of colors and the blue stuff looks baddass on my blue bike! They have fuel line to match. I'm surprised you local bike shops don't carry anything. Mechanics go through tons of the stuff.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- andy9802gt
- If it tastes that good, eat it yourself.
07 Feb 2011 01:13 - 07 Feb 2011 01:14
All bike shops carry it you just have to ask for it. The one I use has it in like 5 or 6 different colors.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
Last edit: 07 Feb 2011 01:14 by andy9802gt.
- 29 palms
23 Feb 2011 21:27
I tried a lawn mower shop today and got everything I needed, Thanks for all the help.
