CV Carb question
- TeK9iNe
- What did you do!?!
Re: CV Carb question
02 Feb 2011 07:30 - 02 Feb 2011 07:49
Your motor would have to be crazy way out of sync to affect midrange performance, but a good vacuum sync is a requirement in my book too.
Does the bike have pod filters, or a different than stock exhaust?
Shim/raise the needles one notch, or with a washer ( .5mm ) and try again. Make sure you have tuned the Main Jets correctly, as they may still be too lean for max power. You should get a slightly sooty exhaust at WOT. DONT LOOK BACK! :laugh: Have a friend watch you.
Good luck!
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 02 Feb 2011 07:49 by TeK9iNe.
02 Feb 2011 08:17
Here's another good link for helpful info about care and feeding of CV carbs.
www.thegsresources.com/gs_carbrebuild.htm
- otakar
02 Feb 2011 15:05
Keihin diaphragms do not have the silk reinforcement, so they will swell if there is any alcohol in the gas you use. This is a common problem with these carbs today. The Mikuni diaphragms have a silk cloth reinforcement inside the rubber and they do not stretch/swell like that.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- TeK9iNe
02 Feb 2011 15:17
otakar wrote:
Less you spray'em with carb cleaner! Then they turn into mini fancy cowboy hats! :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- School Teacher
02 Feb 2011 23:09
Thanks guys i will put this to use.(if it warms up enough to get on the bike)
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
- School Teacher
14 Mar 2011 17:26 - 14 Mar 2011 17:27
otakar wrote:
This is true I have a photo essay to prove it. And it has made a difference for sure. It runs with in a jet and one needle position.
1980 kz1000G1
1980 kz1000G1
Last edit: 14 Mar 2011 17:27 by School Teacher.
- School Teacher
14 Mar 2011 17:28 - 14 Mar 2011 17:31
Got the Diaphrams out of GB.
1980 kz1000G1
1980 kz1000G1
Last edit: 14 Mar 2011 17:31 by School Teacher.
- School Teacher
14 Mar 2011 17:31
1980 kz1000G1
1980 kz1000G1
- School Teacher
14 Mar 2011 17:32
1980 kz1000G1
1980 kz1000G1
- School Teacher
14 Mar 2011 17:32
1980 kz1000G1
1980 kz1000G1
- School Teacher
14 Mar 2011 17:33
1980 kz1000G1
1980 kz1000G1
- School Teacher
14 Mar 2011 17:33
1980 kz1000G1
1980 kz1000G1
