What's wrong? 29 smoothbore vacuum issue maybe?
  • Kahuna360
  • Kahuna360's Avatar Topic Author
Re: What's wrong? 29 smoothbore vacuum issue maybe?
27 Jan 2011 08:47
#426100
Well, no luck on the advance arms. Dropped the throttle cable and accelerated manually, not the cable. Spring is fine not weak. Slides snap back when I release.
Guess I'll rip em back off, change out all float needles and seats, re-adjust floats, pull caps and take a look above the slides and see if tabs are rubbing.
29's can be a real pain in the you know what.
  • hocbj23
  • hocbj23's Avatar
27 Jan 2011 10:50
#426121
I love smokers.U could always hire out in the summer for skeeter control.lol.bj
  • keith1
  • keith1's Avatar
27 Jan 2011 16:39
#426197
you have an air leak then.....as patton suggested, boots may be suspect.......if you dont know the age, just get new ones......pods and a pipe? confirm pilot and main jet sizes and report back.....29's are no more of a pain in the ass than 28's or 26's if boots are bad and they arent jetted right for the application/mods........
  • Kahuna360
27 Jan 2011 17:03
#426208
I will inspect them when I pull the rack off. I did spray carb cleaner around the boots and throttle bodies but got no reactions.
  • Frankn9
  • Frankn9's Avatar
27 Jan 2011 17:13
#426210
did anyone suggest that they may be running lean??
  • keith1
  • keith1's Avatar
27 Jan 2011 17:19
#426211
yep...2 posts ago....B)
  • Frankn9
  • Frankn9's Avatar
27 Jan 2011 17:25
#426213
it was alot further back than that!
  • keith1
  • keith1's Avatar
27 Jan 2011 17:54
#426224
yep, but reiterated again.......:laugh:
27 Jan 2011 17:56 - 27 Jan 2011 18:01
#426226
Kahuna360 wrote:
...What if the float levels are off? I used a cheap caliper. Set them at 23mm. Would 2mm too high cause it?
Should imo be concerned with actual fuel level instead of measured float height.
Clear tube test is the best method to observe actual fuel level inside float bowl.
Good Fortune! :)
[Click on image to enlarge view.]
Last edit: 27 Jan 2011 18:01 by Patton.
  • keith1
  • keith1's Avatar
27 Jan 2011 18:02
#426227
Patton wrote:
Should imo be concerned with fuel level instead of float height.
Good Fortune! :)
i m going with bad boots ...if he had a float level/fuel level issue, he would feel it on the way up....if i understand correctly, he has hanging rpm's on the way down....return spring is good, so are cables from what i have read...lubed the advancer......other than boots, any ideas?......
27 Jan 2011 18:03
#426228
Could use clear tube method to determine fuel level inside smoothbore float bowls
Without a side located drain screw, may collect fuel from hole at bottom of bowl.
Some folks adapt a spare 17mm bolt plug by drilling and fitting a nipple to attach the clear tube.
I just use a cone shape rubber plug pressed into the drain, with a hole through the rubber plug, and the clear tube fitted snugly inside the rubber plug hole. Then hold the rubber plug in position during the measurement.
Some minimal leakage won't affect the results, as fuel volume entering the bowl exceeds any leakage.
Good Fortune! :)
27 Jan 2011 18:06
#426231
Another possible source of air leak could be worn or defective or missing o-rings on pilot air screws. :)
