Rattle-rattle-rattle
  • hoghaterkaw
  • hoghaterkaw's Avatar
Re: Rattle-rattle-rattle
24 Jan 2011 19:13 - 24 Jan 2011 19:15
#425183
After 10 years in storage, I would check to see if you are getting the full battery voltage to the coils. Also check the spark plug caps resistance too. The key/ign switch could be bad as well. Were it my bike I would clean all the wiring connects. Also are you totally sure the carbs are completely clean?
Last edit: 24 Jan 2011 19:15 by hoghaterkaw.
  • testarossa
  • testarossa's Avatar
24 Jan 2011 19:31
#425190
BJ I just found this thread: www.yamahaclub.com/forums/topic/17140-ne...6-radian-idle-noise/
Sounds like the primary drive is a chain, and it can rattle at idle. Apparently Radians are sensitive to carb sync, and according to that thread, the idle should be 1100 rpm. Good luck tomorrow.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Old Man Rock
  • Old Man Rock's Avatar
25 Jan 2011 02:24 - 25 Jan 2011 02:25
#425234
Can't speak for the Yami but in my KZ900 had a similar situation where weirdest noise ever... Sent the AVI clip w/audio to Lar and Plumi... Both replied with "well that's a first"
Best description was a loud squishing/swirling sound off the valve cover... Visual inspection all good, bike ran well but for the intermittent noise... It was loud enough to hear over the Kerker even... :blink:
Anyhoot, off to HF Tools for a $5 Stethoscope...
Followed it all the way down to the oil pump where it got real loud... Damn noise was vibrating/traveling up the timing chain channel and resonating in the valve cover area....
E-bay, $25 oil pump haven't heard it since....
Best $5 I ever spent... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 25 Jan 2011 02:25 by Old Man Rock.
  • hocbj23
  • hocbj23's Avatar Topic Author
25 Jan 2011 11:34
#425386
Ok gents,spent this AM with the bike.Pulled the clutch basket again(Im gettin good at this),rechecked,retightened and reinstalled.Ran a quick check on battery,fuses,switches and all seems well.Drained oil,installed new filter,refilled with 15-40 Rotella and some Seafoam.Pulled valve cover,rechecked chain and guides,some wear but not outside spec.Pulled carbs,cleaned,reinstalled.Started bike ,warmed it up,set idle at 1100RPM.NO rattle.if RPM falls below 1000,bike rattles so I assume the slide valves are the culprit (or maybe the primary) and as long as idle is set right and bike is pulling a bit of a load against the slides-no noise.Thanks all for the tips and time.Ride on and be safe.bj
  • testarossa
25 Jan 2011 11:39
#425387
Bravo! That's how you do it boys. Identify problem. Scratch head. Ask for opinions. Consider the opinions. Develop a plan. Work the plan. Fix motorcycle. Doesn't seem too hard.
2004 ZX-10R
Angola, IN
  • hocbj23
25 Jan 2011 13:08
#425401
Thank you.I had lots of good opinions and all I did was verify what u guys thought.Its great to have some smart friends.bj
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
25 Jan 2011 14:01
#425415
I was going to say my 550 used to have clutch basket rattle too, drove me nuts. Then I sold it :)
  • hocbj23
25 Jan 2011 17:30
#425460
I got that.I really didnt want to sell this little bike though.It is a blast to ride and I got an 11 year old grandson who has been eyeballing it real hard since I got it running.Maybe his starter bike in a couple -three years.bj
  • Motor Head
  • Motor Head's Avatar
25 Jan 2011 17:38
#425466
Kinda off topic, but my Grandpa gave me my first pocket knife, first fishing pole, first bicycle, and so much more. I'll never forget the man, made me what I'm today I suppose.
If you can hang on to it, might be a great Birthday present in a couple years. :)
