The one piece puzzle..
  • nbrider
  • nbrider's Avatar Topic Author
19 Jan 2011 11:07
#423550
I was cleaning my 1983 KZ440 LTD today when I noticed a clear hose, only about 8mm-10mm in diameter. It was setting in the battery area, and It wasnt connect on either end. I have no idea what it is, but it was wrapped behind the battery. I couldnt see where the other end was going to before it completely fell off. Anyone have any idea what kind of hose would run there, And where it goes back into?
Feel free to poke fun if its obvious.
1983 KZ440 LTD
Black paint- Soon to be something new!
  • testarossa
  • testarossa's Avatar
Re: The one piece puzzle..
19 Jan 2011 11:40
#423552
My guess is going to be vent hose for the battery itself. Some motorcycle batterys have a vent that will attach to what is usually a small clear hose. It's intended to vent the acid away from the battery box in case you had an overcharging situation that caused the battery to boil over.
Do you have the battery? Does it have a spigot with a small hose barb coming off the top?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • nbrider
19 Jan 2011 11:52
#423555
I checked the battery, and no it doesn't. Then again, it's a fairly new looking battery and the owner previous to my told me it had just been replaced. The hose has no smell of gas, or oil or anytihng to that matter. So I am assuming it wasnt plugged into anythng, it had infact just been set there after the new battery was put it? maybe? Its almost molded into a three sided square shape from sitting behind the battery housing, So I would guess it hasnt been plugged into anything in a while..
Here's to hoping that's what it is!
Thanks a bunch testarossa.
P.S.: This forum is great.
1983 KZ440 LTD
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
19 Jan 2011 12:07
#423557
No, this forum is the best in the world, and your title sounds like a descriptor for my wife. :laugh:
Yeah, in that spot its most probably a battery overflow line.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Kawickrice
  • Kawickrice's Avatar
19 Jan 2011 12:41 - 19 Jan 2011 12:45
#423570
Sometimes the vent nipple is on the side and you have to lift the battery up a few inches to see it. It will be pointed down and is usually molded onto the side of the top piece. If left disconnected it can leak acid all over and acid is very very corrosive to metal. Ask me how I know this ;)
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 19 Jan 2011 12:45 by Kawickrice.
  • z650c3
  • z650c3's Avatar
19 Jan 2011 13:16
#423576
Bump
c3
1979 z650 c3 first registered in 1981
2006 Harley Davidson VRSCR
Northern Ireland
