my tank is not venting properly (gas cap)
- metrorollah
18 Jan 2011 18:24 - 18 Jan 2011 19:41
Hi,
My KZ650SR-D2 runs awesome. The carbs are perfectly jetted for my 4-1 pipe and pods. I have a hard time keeping the rear wheel straight sometimes. The being said, the one problem I do have is that my tank is not venting, or rather, sucking properly. If I don't set the gas cap on exactly perfect, it starves the petcock, and I have to stop and push down on it several times to let it catch up. I have the SR tank with the key-in-the-center, pop-out cap, not the hinged one.
Any advice on cleaning this cap, it IS gummed up and corroded. Is there a good solution I could let it sit in?carb cleaner maybe? Anyone know how the vent circuit is routed in there?
Last edit: 18 Jan 2011 19:41 by metrorollah.
- bountyhunter
Re: my tank is not venting properly (gas cap)
18 Jan 2011 22:00 - 18 Jan 2011 22:01
On mine, you have to take the cap apart and clean it. There is a gasket and two passages that vent the tank and a small hole between the two sides. Yours is probably plugged up.
Last edit: 18 Jan 2011 22:01 by bountyhunter.
