kz1000 + bs34 cv carbs/pods clarification.
  • otakar
  • otakar's Avatar
Re: kz1000 + bs34 cv carbs/pods clarification.
17 Jan 2011 22:06
#423185
notaduc wrote:
I was looking at the same set, are the all black stock? Or di someone rattlecan those?
The GPz750 had stock black Mikuni carburetors. The other 750s had silver Keihin carbs.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • wagonmaster69
  • wagonmaster69's Avatar
  • 78 KZ1000A2 / 82 KZ1100 Spectre
17 Jan 2011 22:35
#423188
Ware are you from?
I have a set off a 1982 KZ1100 Spectre maybe we can work something out.
Cause I would like to rebuild the set I have on my bike and go with pods also.
  • notaduc
  • notaduc's Avatar Topic Author
18 Jan 2011 09:14
#423270
Will be running custom header/exhaust, pods, he did mention he had a three angle valve job when the head was overhauled.
1980 (mostly) KZ1000
  • otakar
  • otakar's Avatar
18 Jan 2011 10:27
#423280
Those mods still qualify as a stock application. On that engine the GPz750 setup will be the best.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • notaduc
18 Jan 2011 13:54
#423317
Thanks again, should I plan to have to re-jet at all?
  • notaduc
21 Jan 2011 17:51
#424209
keith1 wrote:
gs 1100 head is like apples to oranges.....kawi police carbs? what size?
If by apples to oranges, you mean spacing, I measured a set of gs1100 carbs, they are 75-95-75, I believe is the same as the kz1000.
If not, what did you mean?
  • notaduc
21 Jan 2011 18:44
#424217
Hey, what makes the Keihin carbs junk?
Curious, trying to learn...
Thanks
  • hoghaterkaw
  • hoghaterkaw's Avatar
21 Jan 2011 19:17
#424218
Thanks
Well the Keihin's arn't junk. That said, they are okay as a stock carb on a stock motor. The Keihin has two butterfly valves. The first is the choke plate at the air cleaner end then down stream of the slide there is the throttle plate. The Mikuni has only one butterfly plate, the throttle plate down stream of the slide. So the Keihin's 34's don' flow as well as Mikuni BS 34's giving the Mikuni a better flow rate for a given size.
