Manual petcock for my 77 KZ650
- bloglos
Re: Manual petcock for my 77 KZ650
16 Jan 2011 09:28
That's great info, thanks Jeff. I'm in no hurry for the petcock as i still have to finish rebuilding carbs, so I'll wait to see about the petcocks you folks are getting in.
78 KZ650 C2 - Runner
77 KZ650 B1 - Project
- cyclhed
16 Jan 2011 12:51 - 16 Jan 2011 13:39
Here's a picture of the set-up. I got the adaptor from Z1 and the valve on ebay. It's the same valve as you found at J.C. whitney.
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
Last edit: 16 Jan 2011 13:39 by cyclhed. Reason: add pictrue
- cyclhed
16 Jan 2011 12:54 - 16 Jan 2011 13:36
bloglos wrote:
This is the exact same set-up I just installed on my 82 kz1000 csr and it works perfect. You bolt up the adaptor and scribe mark the inside of the hole where you will need to remove a small amount of material from the original opening so the screen on the new valve will fit up into the tank. I used a die grinder and held the end of my shop vac near while grinding and it sucked up the filings. The adaptor comes with Hylomar sealer and you coat the adaptor and gasket and tank and let it dry for 10 minutes then assemble. Wrep the valve threads with teflon tape and install. Mine does not leak and works great. Don't forget to cap your vacuum port on the carb.
Hmmm, so this petcock,
www.jcwhitney.com/bikers-choice-early-st...ilterid=d9997y1977j3
Should work with this adapter plate,
www.z1enterprises.com/detail.aspx?ID=1741
And all should be good. I think? Unless I've missed something. Not much info on the petcock though. Don't know if there a reserve option or not.
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
Last edit: 16 Jan 2011 13:36 by cyclhed. Reason: add picture
- Jeff.Saunders
16 Jan 2011 16:02
that's exactly the same petcock we used to sell. Some are good, most are bad these days...
Even Tucker-Rocky (the #2 m/c parts distributor in the USA) stopped selling them.
Z1 Ent on Facebook,
