Fuel Rail and Pipe Joint (Tee)
  • bloglos
  • bloglos's Avatar Topic Author
08 Jan 2011 09:26
#420744
Alight, I've been trying to sort out whether I'm going to pull my carbs off the rack to do a full rebuild. Think I'm going to do it, but I told I should consider ordering a new fuel Tee, as they tend to leak once reused.
I checked the file base under my 77 B1 and found the OEM numbers are 92005-1010 (Tee) and 92005-1009 (Fuel Rail).
Those match up under Z1's parts search as ZSM05-1010 and ZSM05-1009 respectively but the description does not mention by bike as being compatible. Is this something I should be worried about.
www.z1enterprises.com/SearchResult.aspx?...&KeyWords=92005-1010
and
www.z1enterprises.com/SearchResult.aspx?...&KeyWords=92005-1009
78 KZ650 C2 - Runner
77 KZ650 B1 - Project
