Confused...PLEASE HELP
- 78kztwin
20 Dec 2010 09:24 - 20 Dec 2010 14:29
The other day my 78 750twin started up on the first try. Now it won't start a week later. Good battery, good points/condenser, charging system good and coils. Only difference is I put on a new balancing hose, hoses for the overflow nipples on carbs and made new gaskets for float bowl screws. also put inline fuel filters on. Doesn't seem like the carbs are pulling in fuel, but I checked fuel flow in lines and is good, even put lines on without filters just in case...nothing, motor will crank but no ignition.
so I'm almost 100 percent sure that my float bowls are filling up and not emptying so no more fuel is getting in...any suggestions
78 kz 750 twin work in progress
Last edit: 20 Dec 2010 14:29 by 78kztwin.
- Rainman
- and a little Kaw shall lead them
Re: Confused...PLEASE HELP
20 Dec 2010 10:54
78kztwin, check the connection for the wire comming from the points. It may have come loose when doing the fuel line revisions.
Good luck,
Jim
Good luck,
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Jim
Quincy,IL
- gengomerpyle
20 Dec 2010 11:02
have you tried priming the carbs?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- 78kztwin
20 Dec 2010 11:31
If not done already, would remove plugs and hold them grounded against the engine while spinning it over and looking for fat blue sparks.
This will help assure adequate ignition power (but not ignition timing which should also be verified to specs using static method).
With ignition issues ruled out, would then consider possibility of issues with compression (including valve clearances), and/or carbs and/or fuel delivery to carbs.
- gengomerpyle
20 Dec 2010 11:48
im not sure with your bike but on mine i have a prime on my petcock. i turn to prime for a few seconds and pull choke and it starts right up but if you do have prime on petcock make sure you turn it off or it will flood the motor.
1982 GPZ750R1 ELR
1971 Honda CB750K
1971 Honda CB750K
- 78kztwin
20 Dec 2010 13:58
20 Dec 2010 14:53
78kztwin wrote:
...new gaskets for float bowl screws---
What sort of "float bowl screws" use a "gasket" that can be hand-made?
...put on a new balancing hose...
Would double-check to assure integrity of hose and connections. If hose or connection is defective, intake stroke might be inhaling outside air through the vacuum nipples instead of inhaling mixture through the carbs.
20 Dec 2010 14:57
Forgive this one :lol: but were the float bowl vent nipples mistakenly connected together instead of the vacuum nipples?
- 78kztwin
20 Dec 2010 15:20
the float bowl screws that cover the main jet...the gasket is handmade but I need to find a new material,,,any suggestions.
20 Dec 2010 17:33
No eBay APP ID and/or Cert ID defined in Kunena configurationUncertain whether float bowl gasket is needed.
