carb question
- 78kztwin
carb question
03 Dec 2010 05:38
I picked up a 78 750b3 from a guy that had no idea what he was doing... lots of things hooked up wrong. My question is; should the nipples on the rubber boots going from the motor to the carbs be connected to eachother or capped.
78 kz 750 twin work in progress
Re: carb question
03 Dec 2010 05:52 - 03 Dec 2010 06:21
78kztwin wrote:
On KZ750 twins, kawasaki.com shows a "balance tube" connecting the two nipples.
Am uncertain how much "balancing" they actually accomplish when connected together.
But neither nipple should be left exposed to open air.
With four cylinder foursome carbs, vacuum nipples should be capped (plugged) unless being used to supply vacuum for another component such as a vacuum operated petcock for example.
Last edit: 03 Dec 2010 06:21 by Patton.
- captchas
Re: carb question
03 Dec 2010 06:09
plugged, those ports are for hooking up a set of vac.gauges to sinc.the carbs when adjusting them. if you have a vac operated pet cock then only one is needed to make the petcock work.
Last edit: 03 Dec 2010 06:28 by Patton.
Re: carb question
03 Dec 2010 06:49
If needed, here's a link about getting info on kawasaki.com such as parts diagrams, part numbers, models sharing same part, availability, etc.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
