Winter Storage
  • mopguy
  • mopguy's Avatar Topic Author
Winter Storage
01 Dec 2010 09:05
#414935
Hi, I am putting my bike away for winter, I added stabiliser to the gas and have a full tank. Should I drain the carburetors or should I leave them alone? I am not sure what to do. Thanks, Tony(mopguy)Sanginesi.
Re: Winter Storage
01 Dec 2010 12:05
#414943
Drain the carbs.
And assure the petcock functions to stop all fuel flow.
If in doubt, detach fuel line from petcock.
A posted message including information about bike year and model will likely elicit better responses.
It's easy to put information in your signature so it will automatically appear in posted messages.
When done, the signature showing information will appear in all posts, past and future.
And the information may be changed as often as desired.
Here's how to do it:
Click here > kzrider.com/index.php?option=com_kunena&...d=8&id=382004#382317
Good Fortune! :)
  • mopguy
Re: Winter Storage
01 Dec 2010 15:31
#414960
Thankyou for the information you have been very helpful. Tony (mopguy) Sanginesi.
  • larrycavan
  • larrycavan's Avatar
Re: Winter Storage
01 Dec 2010 16:25 - 01 Dec 2010 16:27
#414962
I disagree with draining the carburetors. Here's why.
I saw so many snowmobile carburetors that were drained for storage, that the float needles stuck wide open after the remaining coating of fuel dried and turned green.
In the fall, when filled with fresh gas, they would fill the crankcase up with fuel.
I prefer to see the fuel tank freshly filled up and the vehicle started once a month during the off season. Motorcycle or sled....
I do that with my bike and always did it with our sleds. Never a plugged jet or stuck float come next running season.
If the bike has to live in severe cold, either use a battery tender or pull the battery and install it once a month to start the vehicle.. :)
JMO
Larry C
Last edit: 01 Dec 2010 16:27 by larrycavan.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
Re: Winter Storage
01 Dec 2010 18:56
#414989
I agree with Larry. I left my YFZ450 outside under a tarp all last winter in northern Indiana and just started it every couple weeks to move the fuel around and get the oil flowing. Had no problems in the spring when I got it out to ride.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Winter Storage
02 Dec 2010 06:49
#415029
Plus, after adding stabil to the tank you should run it long enough to get the stabil into the carbs. Now your protected top and bottom! ;)
  • TerryK
  • TerryK's Avatar
Re: Winter Storage
02 Dec 2010 20:05
#415108
Personally, I add Sta-bil to the gas, run the bike at for at least 15 minutes, shut it down and drain both the tank and the carbs. In 27 years with this bike, (20 years with Mikuni flat slides) I've never had a problem with the carbs staying clean, as well as the tank. The first few years, I took the bowls off the carbs in the spring just to be sure and I can assure you they are like new inside. Draining the tanki is my preference but I'm quite sure that leaving it full and with stabilizer added will also be fine.
I use this technique with all my bikes and power products. They all start instantly in the spring/fall.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • jeffasaki
  • jeffasaki's Avatar
Re: Winter Storage
02 Dec 2010 20:29
#415111
I do a fresh oil and filter change
Take the bike for a half hr run
Get home drain and pull the tank carbs bodywork
Oil and plug the intakes
Plug the exhaust pipe put it in heated storage with a breathable cover on top
Drain the carbs and give em a sqirt of contact cleaner dry em with a hair dryer bring all removed parts indoors
Them wait till the streets are safe again
Carbs always leak a bit on first start in spring
I let em get wet overnight and dont have any more leak probs over the coure of the season
Always starts right up been doing this for years and never had any probs
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • captchas
  • captchas's Avatar
Re: Winter Storage
03 Dec 2010 04:22
#415121
as a retired auto/marine/mc mechanic, my marine days taught me that there are better ways to store a motor in a safer manor.
i use 2 product's for boats made by MDR called store and start,one is for fuel the other for the oil in the crank case.it's a combo of a stabilizer and fogging oil in one. while it stabilizes the fuel and oils . "something here in the states we all know is a major problem with the additives" ,it also applies a foging oil to the gas tank,valves rings and cylinders to help prevent rust build up.
with thier use one can turn off the petcock and run the carbs out of fuel and not worry about the needles valves sticking open.or jambed shut when the carbs are left full as it coats the carbs inside also with the storing oil film.along with leaving a antirust on the engine and trans parts.
