Air box question
- purls
Air box question
30 Nov 2010 18:29
Hi. I have an '82 Spectre 750 with an empty air box. I plan on putting K&N back in, but don't have the bottom gasket or the plastic holder piece.
My question is: Should I go with OEM and the K&N filter, or does anyone have a better idea that doesn't involve removing the air box? I am not a mechanic.
1983 KZ750 Spectre
1978 KZ650B2A
1978 KZ650B2A
- tybolt99
- From where KZs came
Re: Air box question
30 Nov 2010 19:05
Well I mentioned that i have 82 750 but I don't have air box. The bike came with pods. Now i run it with K&N pods.So I really can't give any suggestion. But many members here will tell you to keep air box.
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- JMKZHI
30 Nov 2010 19:18
Howdy. Since you aren't a mechanic, stick w the stock airbox. You can probably get the needed stuff on ebbaayy.
The cross-reference at Kawasaki.com will show that a bunch of bikes have some of the same airbox parts. Here's a filter holder - KZ650 GENUINE INLET PIPE HOLDER .
I believe the gasket is either felt or foam. If it's nla at the dealer, you could probably come up with something. Or find one on ebbaayy - either new, nos, or used.
Also, supposedly, the Kaw dealers have a nationwide parts lookup, so if a dealer in Timbucktoo happens to have something you need, your local place might be able to get it sent over to their shop.
- ZLife7183
04 Dec 2010 15:51
I have the same bike "83" model by the Gold N Black paint job.
Ran a K&N filter for two years without any draw backs on breathing.
Hence you don"t need the filter reinforcement basket for the soft OEM sponge style.
Hope this helps.
Hope this helps.
1983 KZ750 N2 Spectre
