bike redlines at start up
  • fourstoryfame
  • fourstoryfame's Avatar Topic Author
27 Nov 2010 14:21
#414414
hey guys, im new to th kz but not new to bikes or working on them, still, i cant figure out a major problem im having. i have an 82 kz1000 csr.
i bought the bike and cleaned the carbs. got her started with some ether, but it immediatly goes to redline and i have to shut it off with the key. i have adjusted the idle knob, and mixture screws nothing helps. i still nee to check for an vacuum leak but i thinki would have found one major enough to cause a 9000 rpm idle. please help.
jets are stock,
pod filters
  • TerryK
  • TerryK's Avatar
Re: bike redlines at start up
27 Nov 2010 14:39 - 27 Nov 2010 14:41
#414417
Ummm, stuck throttle, major air leak?
By the way, if you have to use either to start your KZ there is something wrong as you have found out.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: 27 Nov 2010 14:41 by TerryK.
  • fourstoryfame
27 Nov 2010 14:44
#414418
yeah i figured it just needed the ether to help after its been sitting. i think i may have fount the air leak. the nipple?vacuum port on top of carb #3 is not plugged, but do you think that this is a big enough leak to cause the 9k idle?
  • TerryK
  • TerryK's Avatar
27 Nov 2010 14:47
#414419
I wouldnt think it would rev to 9k but you never know. Plug it and try it out. Can you check to see if all 4 carb slides are closing fully?
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • seanbarney41
  • seanbarney41's Avatar
  • '79 kz1000 LTD '75 Honda CB750
27 Nov 2010 19:32
#414459
Last time I encountered this problem it was caused by a severely misadjusted throttle cable. Make sure all the throttle cable ends are properly seated in the adjusters at both ends of the cable. Next try screwing in the adjusters all the way. See how it idles then, the throttle cable will probably have a ton of slack...but if that has cured the engine raceing problem readjust the idle speed with the carb adjuster screw then try to adjust the slack out of the throttle cable with the adjuster at the carb end of cable. Finish fine tuning throttle cable tension with the adjuster at the twist grip. Try and find a manual that covers your bike as these adjustments are part of general maintenance and there will be helpful pictures and model specific instructions. Factory service manual is best but a Clymers or something will cover this pretty well too. And yeah, ya gotta have that vacuum nipple plugged.
  • trianglelaguna
  • trianglelaguna's Avatar
27 Nov 2010 19:34
#414460
awesome.....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
