Which carb design is for what? Out of Curiosity
  • School Teacher
  • School Teacher's Avatar Topic Author
20 Nov 2010 23:47
#413628
If I am looking at say Keihin carbs they sell round slides and flat slides (I’m talking new ones) the question is why? What are the advantages of one over the other? (I’m not talking CV) Any input would help.
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
  • timebomb33
  • timebomb33's Avatar
Re: Which carb design is for what? Out of Curiosity
21 Nov 2010 15:34 - 21 Nov 2010 15:42
#413702
flat slide carbs flow better than round slide carbs.
I THINK MY POWERBAND BROKE
Last edit: 21 Nov 2010 15:42 by timebomb33.
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
21 Nov 2010 15:35
#413704
timebomb33 wrote:
flat slide carbs flow a better than round slide carbs.
They also are shorter and weight less then a similar sized round slide carb.
Build Thread
  • timebomb33
21 Nov 2010 15:42
#413706
there is that as well.
  • Injected
  • Injected's Avatar
21 Nov 2010 15:56
#413710
Throttle response is better on a flat slide...
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
  • Becker
  • Becker's Avatar
  • The Doctor Will Rise Again
21 Nov 2010 18:55
#413736
With roundslides you have to use a smaller diameter carb because if you go to big the engine will have good top end and thats it. With a smaller diameter carb you have better all around peformance but the top end suffers.
We went over this in snowmobile technology in college and I can't remember exactly why but the flatslide can run a larger diameter for good top end and still maintain good all around performance. I can't remember why or how it does it though.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • DoubleDub
  • DoubleDub's Avatar
21 Nov 2010 19:09
#413738
So why are there so many round slide carbs out there if this is true? Seems odd that they would be used for so many years from the factory if they weren't "better" in some way.
Do they just provide better all around (low,mid) performance versus the flat slide carbs?
21 Nov 2010 21:00 - 21 Nov 2010 21:01
#413751
Don't know but been told that sometimes it's easy to tell the flat slides are working better, because they're rattling. :laugh:
Good Fortune! :)
Last edit: 21 Nov 2010 21:01 by Patton.
  • Becker
  • Becker's Avatar
22 Nov 2010 06:35
#413766
Well, like I said, that is what they told us in snowmobile theory. On sleds you are on the throttle alot and so the manufacturers are looking for performance over economy. maybe the roundslides are more efficent MPG wise??
I won't pretend to know what manufacturers are thinking when they make these decisions.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
  • larrycavan
  • larrycavan's Avatar
22 Nov 2010 06:36 - 22 Nov 2010 06:41
#413767
Bingo :)
I flowed and posted the numbers for RS34 Mikunis. The're not impressive in the flow department.
Size wise, you can get good throttle response out of a slightly larger flat slide as you can on a round slide without way over carbureting the engine.
Carbs meter fuel well or poorly based on the signal strength present at the fuel discharge point.
Last edit: 22 Nov 2010 06:41 by larrycavan.
  • larrycavan
22 Nov 2010 06:39
#413769
Good Fortune! :)
That would be incorrect :laugh:
  • turboguzzi
  • turboguzzi's Avatar
22 Nov 2010 15:04
#413817
rounds simply existed before flats... round slides are easier/cheaper to manufacture.
Flats have another advantage of rollers in the slide so the slides dont stick under high engine vacuum and need less spring force to close, easier on the wrist.
TG
