Couple of Questions
- TIKI
Couple of Questions
12 Nov 2010 18:49
Couple of questions about a 73 Z1
I want to disconnect the chain oiler because of the mess. Will it cause any harm to the pump to clean out the reservoir tank and not fill it, leave it dry.
While cleaning out the carbs should I apply a little light oil to the slides and the rotating parts in the top cap, does anything need lubing in the carbs.
1973 Z1900 Santa Rosa,CA
- TerryK
Re: Couple of Questions
12 Nov 2010 20:55
Just take the pump off.
As far as I know, no lube is needed in the carbs.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
