Gas leak from carbs
- RonBo
Gas leak from carbs
11 Nov 2010 15:12
When Ilet the bike sit without turning the petcock off
any suggestions as to what is wrong?
- timebomb33
Re: Gas leak from carbs
11 Nov 2010 17:38
weak float valve springs
I THINK MY POWERBAND BROKE
- DoubleDub
11 Nov 2010 18:51
It has generally been stated here (especially if you don't have a vacuum operated petcock) that this is normal due to the pressure of gravity. It is recommended that you shut off the fuel when the bike is not running.
But as TB pointed out, the spring in the float valve is probably weak from age and use.
11 Nov 2010 21:11 - 12 Nov 2010 14:42
When float valves and float mechanism are both functioning perfectly, fuel should remain at the service level inside the float bowl without reaching the overflow circuit.
Some gruesome details ---
Float valve consists of a seat (with an orifice) and the pointed needle that fits into the seat.
Fuel entering the carb goes first through the float valve, and is supposed to stop filling the bowl when the float lifts the needle which presses into the seat.
The least failure of complete seal between the needle and seat will allow fuel to keep flowing through the float valve into the bowl. And eventually the fuel level rises far enough to reach the overflow circuit.
Such failure to completely seal often results from crud or speck of grit at the interface between the needle and orifice.
Good reason to install an aftermarket in-line fuel fuel filter, necessary to supplement the coarse screen filter in the petcock.
Typically, the overflow circuit exits from a nipple on bottom of the bowl where a hose attaches and runs over the swing arm to discharge underneath the bike.
Some carb designs do not include an overflow circuit.
Last edit: 12 Nov 2010 14:42 by Patton.
Last edit: 11 Nov 2010 21:42 by Patton.
11 Nov 2010 21:48
Here's an illustration showing how the float (float tang) works with the float valve to control fuel flow into the bowl.
[Click on image to enlarge view.]
- hal0tw0
12 Nov 2010 05:23
My carbs do this too, but I plan to go through them thoroughly this winter and replace those assemblies and check the jetting. I just turn off the petcock after riding.
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
- blipco
- 2002 KZ1000P
12 Nov 2010 06:57
All of the above but lets not forget about filling the motor completely with gas.:ohmy: Keep an eye on the oil level and give it a sniff.
- RonBo
17 Nov 2010 17:32
Thanks a lot for the valuable info , I'll take these suggestions in consideration when trying to fix this situation , probably dirt in the float nneedle orfice.
If I didn't mention before,my bike is a stone stock 1975 Z-1 B
Thanks>>>>>>>RonBo
Thanks>>>>>>>RonBo
