Temp Altitude Humidity Effects on Jetting
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
24 Oct 2010 09:03 - 24 Oct 2010 09:05
#408707
Now that the temp here in AZ has cooled down significantly, off to the bike salvage yard (ZX636 Clutch Perch) yesterday for morning temp @ 73 degrees... Nice.....
I noticed some real minor popping during deceleration...
AT a stop light, noticed she was stumbling a tad at idle...
hmmm, ok so what have I learned in jetting....
Higher altitude equates to less air more gas so leaner is required...
Cooler air equates to density change so more air less gas... Richer is required...
Out with the long blade screw driver I have tucked in the tail section, tweak the slow jets 1/8th turn for richer setting...
All better..... :) See even an old fart can learn.... :blush: :laugh:
Possibly a needle clip position change (Richer) as it gets cooler here is required....
For those interested, nice write up here....
www.justkdx.dirtrider.net/printcarbtuning.html
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 24 Oct 2010 09:05 by Old Man Rock.
  • loudhvx
  • loudhvx's Avatar
Re: Temp Altitude Humidity Effects on Jetting
24 Oct 2010 10:15 - 24 Oct 2010 10:18
#408721
One of the things I've learned is that if you jet for the best power when the bike is fully warmed up, you actually end up pretty lean for most other conditions.
If you want the most drivability, you will end up jetting a little richer than you want for best power. This means the bike will actually feel a little sluggish on really hot days when the bike is warmed up all the way.
As with most things, there must be some tradeoff. I usually jet somewhere between best power and best drivability, but that means I tend to stay on the choke a lot longer on cold days.
Last edit: 24 Oct 2010 10:18 by loudhvx.
  • Old Man Rock
24 Oct 2010 11:03
#408728
Choke... Pretty weird where these CR's they don't like choke at all.... If choke any and I mean any amount ~ 1-2mm pull on is about it.... :huh:
So off to mi amigo experts to find out more info... Keihin CR's are known for this... Ahhhhhhhhhhh... I see....
Granted, AZ cold is a hell of a lot different then up North/Back East cold so have to consider that as well....
As previously mentioned due to AZ heat index, I run a tad more on the rich ~ 13.8-14.1 Stoich on the A/F ratios.... Power and cooling effects...
I've encountered this same scenario on North mountain runs 1500 ft elevation changes where even in the summer months, higher elevations, had to lean out for better idle - 1/4 throttle/rpm ranges.... Just the way it works out....
All good.... B)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • loudhvx
  • loudhvx's Avatar
24 Oct 2010 11:11
#408729
Yeah, the TK-22 chokes are literal chokes. They are a plate that slides down over the intake. There are little flaps that open up if the engine vacuum is pulling too much. Crude, but effective. You have to play with the lever if you want to get on and ride right away.
Enricher type chokes seem to be a lot less finicky.
  • larrycavan
  • larrycavan's Avatar
24 Oct 2010 11:48
#408738
You're probably aware of this but those TK choke plates had a nasty habit of fall off and getting sucked through the engine....
  • loudhvx
  • loudhvx's Avatar
24 Oct 2010 16:52
#408840
Yeah I have a few write ups here on how to prevent that. Just basic inspection really. The pins walk out from vibration, but you can put them back and re-peen them or glue them so they don't walk out.
However, I would prefer a solid plate and have been mulling over some ideas on that. Or at least simple ways of doing that and adding more "click" positions to the choke lever.
One of these days i hope to finish a TK-22 website.
