83 KZ1100 LTD Shaft Carb Rebuild Kit where to find
  • pctech101
  • pctech101's Avatar Topic Author
15 Oct 2010 06:38 - 15 Oct 2010 07:04
#406797
Please help me with finding a rebuild kit for my bike.
From what I have read, are the carbs the BS34?
If you know a cheap reliable place to get rebuild kits for the carbs, please provide link to compatible kit.
Thanks
As a side note...
How much have people paid to have their carbs (same as mine) rebuilt and synced/tuned?
I have skill enough to rebuild carbs but I dont know how to tune them afterwards.
I am trying to figure costs to determine wether I want to send them to wired george or rebuild myself and have local shop tune/sync...
Last edit: 15 Oct 2010 07:04 by pctech101.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Re: 83 KZ1100 LTD Shaft Carb Rebuild Kit where to find
15 Oct 2010 13:41
#406862
I'd check in this order
1. Local shop that you trust
2. Z1E - there's a link in the Vendor area of this site
3. Bike Bandit - ditto on the link
It's been a while, but the last time I had a set of carbs cleaned, a DJ kit installed and synch = about $300.
It's not all that complicated, though you will need to pick up a couple of specialty tools that you can continue to use at subsequent tuneups.
  • havakaw
  • havakaw's Avatar
16 Oct 2010 06:29
#406987
Got mine for my 82 shafty 1100a2 on E-bay from "Georgefix".Got all 4 for $80.Came with o-rings,bowl gasket,float needle and seat,and pilot screw and spring.I think they even had new main jets too,but I was installing a Dyno Jet kit at the time,so I used thiers.If your bike is stock and runs good,the only thing you may need to fiddle with after is the idle speed and pilot screw setting.
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
  • pctech101
16 Oct 2010 12:28
#407033
I got my bike back in July and she hasnt ran 100% correctly. There is a misfire I havent figured out. Anyhow, I believe the bike had been setting. I am slowly going over the bike. I might do a rebuild of the engine this winter. I am sure the carbs could use a rebuild and new jets
  • pctech101
17 Oct 2010 16:38
#407262
george fix says these should work on my bike.
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...VIP:watchlink:top:en
will someone that knows more about this, help me verify. thanks
  • captchas
  • captchas's Avatar
19 Oct 2010 05:47
#407561
www.carbkitscapital.com/
www.motorcyclecarbs.com/index.cfm , also sudco has kits
or better yet while a bit costly, ship the carbs off to wiredgeorge in texas and have him rebuild them to like brand new.
  • pctech101
20 Oct 2010 07:23
#407739
Just want to say thanks for the replys...
I will have more questions in the future...
