Warning: Undefined variable $end_tag_params in /home/kzride5/public_html/libraries/kunena/External/Nbbc/src/BBCode.php on line 2298
Help ID these carbs please
  • hal0tw0
  • hal0tw0's Avatar Topic Author
17 Aug 2010 03:28
#391572
on my 76 kz900, going by all the carb ID info I can find, it seems these are 26s but the PO said they were 29s....
Thanks!
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: Help ID these carbs please
17 Aug 2010 04:10 - 17 Aug 2010 04:11
#391576
In these discussions there should be the i.d. to your carbs.
They are not 29's. Roy
www.wgcarbs.com/forum/index.php/board,3.0.html
Last edit: 17 Aug 2010 04:11 by roy-b-boy-b.
  • testarossa
  • testarossa's Avatar
17 Aug 2010 05:09
#391583
Lets sees a picture from the other side. Does there appear to be an accelerator pump attached to the bottom of the #2 carburetor? It looks like you have the crossover tubes in the float bowls for the accelerator pump. If that is the case then you have VM28ss carbs from a KZ1000. I have no experience with the pumpers, but I hear that they are a little tougher to tune with. I searched around wiredgeorge's site and the only reference to a 113 1 stamp number was a VM28ss.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • roy-b-boy-b
17 Aug 2010 05:50
#391595
They also made a 26 pumper. I just shipped my 26 and 28 pumpers off and can't check numbers.
  • Kawickrice
  • Kawickrice's Avatar
17 Aug 2010 06:58
#391608
I would agree they are not 29's. Remove the carbs and measure the ID of the intake side that mounts to the boots to be absolutely sure.
My 28's have the air/fuel mixture on the bottom and my 24's on my 650 have the air/fuel on the side but the barrels have ribs. I believe the 29's are on the side too like yours but the bowls on yours are not of the 29's.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • hal0tw0
17 Aug 2010 07:47
#391623
Thanks guys!
It does have accel pumps. I wll post another shot of the other side. I have a cheapo caliper, I dont have a repair manual for this bike so I was hesitant to just start jumping in and taking stuff apart. Ive rebuilt/rejetted carbs sucessfully before so that doesnt intimidate me at all.
Thanks
  • PLUMMEN
  • PLUMMEN's Avatar
17 Aug 2010 07:59
#391626
those bowls can be used on 29s also B)
  • stonemaster
  • stonemaster's Avatar
17 Aug 2010 08:55 - 17 Aug 2010 10:04
#391656
measure the bore
Last edit: 17 Aug 2010 10:04 by stonemaster.
  • Kawickrice
17 Aug 2010 10:29
#391675
On the early ones they will fit I think but I could be wrong but the later ones you had to use the bowls with the big nut on the bottom. Thats why I told him to measure the intake throat to be sure.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • stonemaster
17 Aug 2010 12:53
#391703
my 73 28mm bowls have the 17 mm drain, my 74 carb set is a 28 as well but with that same bowl shown,
  • Jack
  • Jack's Avatar
17 Aug 2010 13:09 - 17 Aug 2010 13:32
#391705
Most likely 26's if stock. 29mm. smoothbores have the 17mm. drain cap on the float bowl bottom, like the oem 28mm. carbs from a '73 Z1. In 1974 Kawasaki put the 28's with the drain screw bowl as pictured above on the Z1.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Last edit: 17 Aug 2010 13:32 by Jack.
  • PLUMMEN
  • PLUMMEN's Avatar
17 Aug 2010 13:22
#391708
i know they fit the ones that suddco sold in early-mid 80s anyway B)
