need to replace the carburetors on my '82 spectre
- reaver573
15 Jul 2010 18:02
I bought this bike in May of this year. Just today, I learned that have to replace the carburetors :ohmy:. Any suggestions as to where I might find some?? I have been advised to stay with the stock carbs (34 mm keihn cv's).
- TeK9iNe
- What did you do!?!
Re: need to replace the carburetors on my '82 spectre
15 Jul 2010 18:56 - 15 Jul 2010 18:58
Replace the carburetors? Why?
Usually they are just rebuilt, at like a 1/5 the cost.
? Anywho, eBay is said to be a good place.
You can try Wired George Carburetors
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 15 Jul 2010 18:58 by TeK9iNe.
- trianglelaguna
15 Jul 2010 19:00
welcome
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- otakar
15 Jul 2010 19:09
If you are going to replace them than get a set of Mikuni BS34s. They are much better than the Keihins. All the higher performance bikes used the Mikunis.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- reaver573
15 Jul 2010 20:13
Thankyou for the info. I will check into them. Oh and yes, I will post some pics of my bike. It's stock, with the addition of Vetter Saddle bags/trunk
- reaver573
15 Jul 2010 20:29
Mikuni BS Type 2 Carburetor. Are these the same as the Mikuni BS34's that were suggested?? Can't seem to find anything under BS34.
As to why I need to replace the carbs, they have a lot of varnish on them and one of the diaphram/pistons appear to have seized in the opening. Two different shops (One a specific Honda/Kawasaki and the other one where I bought the bike) recommended replacing them :S.
- reaver573
16 Jul 2010 04:27
OK, so I finally got the diaphragm/piston out of the Carb body, but i kinda messed it up. Anyone know where I can get a replacement diaphram/piston and that needle that goes inside?? Bike Bandit charges $100+ for that part.
As far as swapping over to the Mikuni BS34's, I'm still investigating that idea as well.
- JMKZHI
16 Jul 2010 04:54 - 16 Jul 2010 04:55
Without really knowing, the stock carbs on your bike might be BS34s. A factory manual will answer that question. If you don't have a manual, go ahead & get one. You'd need the KZ750-Shaft manual - the ones I've seen on ebbaayy have a Spectre on the cover. Or you could try wiredgeorge's website to verify what you've got (wgcarbs.com).
As for BikeBandit's price, please note that the part may not be available: the vacuum piston valve is listed as Cancelled at Kawasaki.com. BB & a lot of online places show a price for everything in their parts diagrams, but they do not have nor can they get a lot of that stuff. When I need a part, I check the Kaw site first to see if it's Active. The info at Kawasaki.com isn't always 100% correct, but it's a good place to start.
Z1Enterprises.com has stuff for your bike. They don't list everything, particularly oem parts, so if you don't see something, contact them w your needs. The folks at Z1 are knowledgeable & helpful, and the shipping is usually fast.
Last edit: 16 Jul 2010 04:55 by JMKZHI.
- 9am53
- homebrew, and some bbq
16 Jul 2010 05:17
Allthough otto didn't shamelessly plug his ad, he is selling some slides and diaphrams for the keihin 34's in the classifieds section of this site for a good price...
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- otakar
16 Jul 2010 07:21
The problem we have in this thread is that we are going under the presumption that these are Keihin carbs. The KZ1100-D1 came with Mikuni BS34s. I think that a couple of pictures of what carbs these are would really help. In in fact these are Keihin CV34s than yes I do have a set of complete slides with needles and springs.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- reaver573
16 Jul 2010 11:04
kk, good idea. I will get some pics of the carburetors.
- reaver573
16 Jul 2010 12:08
OK, the carbs are Keihin, not Mikuni. I have taken pic of one area of concern I have with the carbs. On the breather box side, one of the carbs has a crack in it.
Also there is a fair amount of rust (??) in the throats of two of them. I am hoping that I can sand the rust down so that the diaphram/pistons will work smoothly (any thoughts??).
If y'all don't see any issues with the crack, then I would like to find out more about the parts that Otto has for sale.
