Bog at 4 - 6k in any gear....
  • Kingchiefa
  • Kingchiefa's Avatar Topic Author
  • To each thier own.
21 Jun 2010 15:50
#377333
My bike bogs down when reaching 4K rpm and continues through 6K. What would cause this and how do I fix it?
1979 KZ1000 ltd b3 Currently in Troy, PA. Hope to some of you on the road.
  • anarki650
  • anarki650's Avatar
Re: Bog at 4 - 6k in any gear....
21 Jun 2010 16:39
#377349
What's your set up? Air box or pods? Exhaust? Jetting? Could be a lean condition, but could be a lot of other things too. Need more info...
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • bountyhunter
  • bountyhunter's Avatar
21 Jun 2010 17:56
#377377
Mine would do that when the needles were adjusted too rich.
  • Kingchiefa
21 Jun 2010 19:09
#377413
pods, 4 to 1 straight vance and hines. It is running rich, jets at lowest setting. Removed #3 air pod and the bog went from 4-6 to 4-4800. Carbs being cleaned now. But I want to make damn sure that replacing the air pods afterward will help the problem.
  • anarki650
21 Jun 2010 20:07
#377439
Would raise the needle a step and see if that fixes your woes.
09 Kawasaki ER6n
Omaha NE
  • Old Man Rock
  • Old Man Rock's Avatar
21 Jun 2010 20:09
#377440
Carbs in sync?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • otakar
  • otakar's Avatar
21 Jun 2010 20:39
#377448
A bog in this range would usually indicate too lean on the needles. A stutter would indicate too rich in the needles.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
21 Jun 2010 21:08
#377456
While riding, could add a little choke during the bog to determine whether performance improves, or worsens, or stays the same.
May aid diagnosis.
Good Fortune! :)
  • Old Man Rock
22 Jun 2010 04:19 - 22 Jun 2010 04:22
#377483
Well before anything, perform/confirm carbs are in sync...
Bogs or falls flat on it's face?
Falls flat then too lean...
A method Larry taught me is during a ride, rev it up to 5/6 grand and hold it steady in 5th gear, does she run smooth smooth or sputter/oscillates as if running out of gas/clogged fuel line "henceforth fall flat on face" etc...?
Also, same scenario, let go of the throttle, let her snap shut, does she back fire, pop out the exhaust?
If either of the above holds true, too lean change to a richer clip position if optional on your setup or richer needle.
As Patton mentioned, pull the choke on a tad, she runs better then yup, too lean...
Plug conditions would also provide you some insight to running conditions...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 22 Jun 2010 04:22 by Old Man Rock.
  • Kingchiefa
22 Jun 2010 16:10
#377606
Old Man Rock wrote:
Carbs in sync?
Yeah carbs are sync'd perfectly.
  • Kingchiefa
22 Jun 2010 16:12
#377608
Why would you raise the needle a step? Wouldn't that create a richer mixture?
  • Kingchiefa
22 Jun 2010 16:24
#377611
it is a stutter not a bog... My bad guys.
