Which carbs do I have?
- Zthou1977
03 Apr 2010 04:58
Hi all,
Due to some engine troubles I am going to clean my carbs. Because I will be boiling them in a lemon juice/water mixture, I will need new gaskets. Trouble is, I am not sure which carbs I have. The bike is a 1977 Z650B1, which should have either Mikuni VM22SS (Kawasaki manual) or VM24SS (Haynes manual).
Measuring the inner diameter of the carbs exits, I get about 26mm (25.8-something). Doesn't that mean I have VM26's?
If so, how should these be jetted? I use the standard airbox/filter and a Marshall 4-1 that (according to the factory) does not need rejetting.
Thanks!
Thanks!
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
- Nebr_Rex
Re: Which carbs do I have?
03 Apr 2010 05:06
Zthou1977 wrote:
did you measure the inside diameter on the cylinder head side?
Hi all,
Thanks!
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Zthou1977
03 Apr 2010 05:16
Nebr_Rex wrote:
Yes, it is about 26 mm (25.8 or so). Strange thing is, I have a later set of Mikuni carbs (with a different kind (stump instead of sharp) and position (diagonal on the side instead of at the bottom) of the pilots). This later set also measures about 26mm on the inside diameter on the cylinder head side. These were sold to me as a set of late-model Z650 carbs.
- Mcdroid
- Gone Kwackers
03 Apr 2010 05:36
I have a set of verified VM26SS from one of my KZ1000A1's off my bike as I type. They measure 26.6mm...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- JMKZHI
03 Apr 2010 06:04
Take the measurement inside the carb bore near the throttle slide.
The VM24 carbs measure ~26mm at the engine side opening, but 24mm near the slides on either side.
- Bluemeanie
03 Apr 2010 06:11
I could be wrong (and most likely am! :woohoo: ) but heard that the 24's had the three ribs on the body and the 22's did not?
- Zthou1977
03 Apr 2010 06:26
@ JMKZHI:
I just tried to measure the inside diameter at the slide. But because I only have a slide caliper that cannot quite reach there, I had to align it by eye. Best guesstimate is that the diameter at the slide is 22mm. It is also the most likely, as the Kawa manual says so. I cannot measure the newer set, as I put these on the bike yesterday.
All of this started because it would only run on three cylinders. With the newer carbs (which are spotless inside, and with the vacuum line capped) the bike wouldn't even run.
Guess I'll have to order 4 carb kits and wait. Not a problem right now, as I can only work on the bike between the downpours. Ghastly weather here.
@ Bleumeanie:
The carbs have three ribs, like yours.
Thanks for the replies everyone!
@ Bleumeanie:
- Old Man Rock
03 Apr 2010 06:26 - 03 Apr 2010 06:31
@ Z1... Carb Identifications for KZ models...
www.z1enterprises.com/reference/z1-carb-guide.aspx
Carb Theory and tuning manuals...
kzrider.com/index.php?option=com_docman&...d&gid=461&Itemid=108
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 03 Apr 2010 06:31 by Old Man Rock.
- Old Man Rock
03 Apr 2010 06:47 - 03 Apr 2010 06:47
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 03 Apr 2010 06:47 by Old Man Rock.
- rstnick
03 Apr 2010 06:59
Try fitting a socket from your socket set into the engine side of the carb bore.
Find the largest one that matches the fit up to the slide, then measure the outside diameter of the socket.
Both VM22SS & VM24SS carbs have the 3 ribs IIRC.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- RonKZ650
03 Apr 2010 07:45
I've tried measuring carbs and they never measure the mm you expect. Yes the 22 and 24s have the ribs, the 26 and 28 are larger at both inlet and outlet so if you have the stock airbox these are not what you have. All 22-28mm carbs from Mikuni use the same gasket, some aftermarket are trash and don't have the hole cut for the acc pump on the pump carbs used in 79-80, but all factory Kawasaki gaskets were the same.
- JMKZHI
03 Apr 2010 07:53 - 03 Apr 2010 07:55
Zthou1977 wrote:
I simply cut a piece of stiff cardboard to 24mm then use that as a measuring device.@ JMKZHI:
I just tried to measure the inside diameter at the slide. But because I only have a slide caliper that cannot quite reach there, I had to align it by eye....
Last edit: 03 Apr 2010 07:55 by JMKZHI.
