Done Everything, Still Has Hanging Idle
  • redwood
  • redwood's Avatar Topic Author
  • 81 650 CSR
20 Feb 2010 19:16 - 20 Feb 2010 19:17
#349357
Alright,
Rev the engine, every now and then it hangs up around 4k or so, doesn't happen every time.
-No air leaks, guaranteed.
-Carbs have been cleaned semi-professionally (friend runs motorcycle restoration business, took them apart, cleaned ultrasonically).
-Advancer does not stick.
-No cables binding, brand new cables.
-Idle set properly.
-Adjusted the valves a few days ago.
Could the carbs be at fault? Leaking gas into venturi from somewhere?
Could the air injection system be doing something detrimental? I guess I could try blocking the valve cover ports and see if that fixes it. :angry:
Last edit: 20 Feb 2010 19:17 by redwood.
  • MFolks
  • MFolks's Avatar
Re: Done Everything, Still Has Hanging Idle
20 Feb 2010 20:04
#349372
I'd check/replace the rubber vacuum plugs(the ones used for carb sync.) and then check the rubber vacuum lines.
Tried the trick of spraying carb cleaner on the hoses/lines while the engie is running? If the rpm goes up, you've found your leak.
  • anarki650
  • anarki650's Avatar
21 Feb 2010 06:12
#349400
In my experience hanging idle usually means lean. Since you're certain carbs are clean and no air leaks (on both airbox and carb holder side hopefully), you might check the fuel supply. Do you have a fuel filter installed? If so is it set to flow the right direction? Is your vacuum petcock not feeding correctly? Might need rebuilt/replaced if the diaphragm isn't functioning correctly. Or it could be something as simple as needing a new vacuum line between the petcock and carbs.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • redwood
  • 81 650 CSR
21 Feb 2010 07:21
#349418
Vacuum plugs are brand new. All the vacuum hoses are brand new.
I'd like to say the carbs are completely clean, but maybe something didn't cleaned up properly? What could it be?
I've sprayed all up and down this thing, no leaks. The only place it could be leaking is where the vacuum line meets the carbs on that brass plug. But it should have been reseated properly after the cleaning.
Would incorrect float levels cause this? How can it if the slides close after blipping throttle?
  • otakar
  • otakar's Avatar
21 Feb 2010 07:33 - 21 Feb 2010 07:36
#349423
+1 but it would help if we knew what type of carbs we are talking about. That way we can narrow it down to, Mechanical, Vacuum, Fuel delivery, Fuel supply. Also we need to know if you are using a stock air filter, or if you changed into pods. Pods will change the entire dinamics of carbs especially CV carbs. Some CVs must be quite a bit modified to work with pods at all.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 21 Feb 2010 07:36 by otakar.
  • redwood
  • 81 650 CSR
21 Feb 2010 07:46
#349426
Completely stock. No pods, and I believe I have VM24's.
  • Bluemeanie
  • Bluemeanie's Avatar
21 Feb 2010 08:02
#349432
See if you can get it to do it with cables disconnected. That will narrow it down. Sounds like something mechanical hanging up to me?
  • redwood
  • 81 650 CSR
21 Feb 2010 08:50
#349442
There is slack in the cables though. If it watch from the side and push on the cables, nothing is staying open, there is no tension keeping the throttle crank slightly open.
  • Old Man Rock
  • Old Man Rock's Avatar
21 Feb 2010 09:18
#349443
I believe what Blue is sayings..... Cables can be slack but the hang up is internal where the metal stranded cable itself is catching on the spiral jacket sleeve... Spray some lubricant down the cables and confirm...
Maybe I missed it but when it hangs on high idle, whats the position of the carb return spring mechanics?
Meaning, is it still above the stopper bolt...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • otakar
  • otakar's Avatar
21 Feb 2010 09:49 - 21 Feb 2010 09:50
#349448
Richen your idle screws by closing them all the way in and than screw them out 1/2 turn richer than they were. Make sure that you remember what the original setting was. See if it still persists after that. This is a quick way to confirm or eliminate one possibility. Since You did not tell us exactly what carbs they are I can not tell you if they are Air screws or fuel screws. This will determine weather you will turn them in by an extra half turn or turn them out by an extra half turn. someone here who has a 650CSR might enlighten us on that info.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Feb 2010 09:50 by otakar.
  • anarki650
21 Feb 2010 10:10
#349451
81 csr should have vm24 with accelerator pump for stock carbs. These have the air screw on the top side of the carb.
What do the plugs look like? A lean cylinder would give you a white(ish) plug, would possibly help narrow the search to know that info. If all plugs are reading correctly I'd be inclined to agree that a throttle cable might be binding up.
09 Kawasaki ER6n
Omaha NE
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
21 Feb 2010 10:29
#349455
On my vm24's I found the rivets that hold the cable mount bracket have become lose; making the bracket have a significant amount of play in it. This caused the idle to hang on my bike (I went through 3 cans of starter fluid looking for a vacuum leak that did not exist!)
My quick fix was a zip tie to lock the bracket in place; next time I pull the carbs for a jet change (spring) I will drill out the rivets and put a couple nut/bolts there to lock it down tightly again.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
