carb jet question.
  • lapeerray
  • lapeerray's Avatar Topic Author
carb jet question.
22 Nov 2009 07:27
#335185
Riding season is over so its time to make changes. So Im running 4-1 exhaust stock airbox with k&n filter. What changes do I need to make to my carbs? Thankyou all mighty gods of kaw!:ohmy:
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: carb jet question.
22 Nov 2009 08:37
#335195
what did you change?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Old Man Rock
  • Old Man Rock's Avatar
22 Nov 2009 08:46
#335197
If the performance was optimum during riding season, no back firing or exhaust popping, fall on it's face acceleration, lull from dead stop, carbon plugs, poor idling etc...
Whats to change regarding your jetting... ;)
Throw some stabil in the gas tank, run it through the carbs for a little bit and store her away...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • newOld_kz1000
  • newOld_kz1000's Avatar
  • FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
22 Nov 2009 11:49
#335219
Is your 4-into-1 loud or close-to-stock quiet?
If it's a loud one, *and* you remove the rearmost plastic parts of the airbox (under the seat) up to but not including the air filter containing-box -- you're flowing a *bit* more air through the motor and might notice a little extra oomph going up one jet size on the pilot jet and one larger main jet.
But without any change to the stock airbox other than a K&N filter, *and* if the pipe is baffled enough so that it's quiet -- you're not flowing much more air through the motor and jetting changes *may* be unneeded.
If you just want to tinker over the winter -- pull and clean the carbs and go up 1 or 2 jet sizes as above and see what the plugs look like and how the bike responds, who knows -- maybe at your elevation the bike will tolerate being richened up a bit. The closer you are to sea level the denser the air is, and you can match that with bigger jets.
I sourced a bike out of Denver (the 'Mile High city') and even though the bike ran excellent at 5000 feet above sea level in Denver (not so much air up that high per cubic volume as at sea level) -- the carbs had to be made richer with bigger jets because I'm at sea level here in California.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
  • lapeerray
25 Nov 2009 18:05
#335947
nothing yet, but my carbs leak, they accelerate just fine so they need aslight rebuild . everything is totaly stock right now im adding k&n and 4into 1 exhaust
  • Nebr_Rex
  • Nebr_Rex's Avatar
25 Nov 2009 18:14
#335950
Try the next size bigger on the mains(97.5 to 100),one size up on the pilot and raise the needle one groove or if there is just one use a small 4mm dia. washer.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • lapeerray
28 Nov 2009 16:08
#336325
Thanks everyone for your help. I have put this mod on hold for now as I purchased the wrong headers at on return. I put the headers on ebay if anybody knows what they are off or is interested in them let me know
  • lapeerray
28 Nov 2009 16:17
#336328
  • lapeerray
28 Nov 2009 16:18
#336329
  • lapeerray
28 Nov 2009 16:19
#336331
  • lapeerray
28 Nov 2009 16:20
#336333
do i have enough pics yet:ohmy:
  • timebomb33
  • timebomb33's Avatar
28 Nov 2009 17:17
#336341
the way the head pipes are angled it might be off of a cb 750 s.h.o.c motor from 69 to 78 but that's just a guess.
I THINK MY POWERBAND BROKE
