Carb Diaphragm cracked: Fixable?
- bountyhunter
04 Dec 2008 16:35 - 05 Dec 2008 00:11
I needed to change the needles on my BS-38 Mikunis, I went back to the stock ones because it was running a shade rich with the Keyster needles. When I was putting the left piston back in, I held it up to the light and could see a small crack in the rubber out near the edge maybe 1/4" long. The rubber has "ruffles" at the edge and the crack runs in one of those.
I put the bike back together and it still runs pretty good (better with stock needles). Idles smooth, accelerates well, no hesitation. I can't detect any uneven running and it pulls real hard when I rip the throttle open at either low or high speed. The tear may have been there for some time, I can't see anything new except for a slight change from the leaner needles. Spark plugs look OK.
Do I have to fix that stupid diaphram? Can you put some RTV rubber on it or is it toast?
Last edit: 05 Dec 2008 00:11 by bountyhunter.
- kzkx
Re: Carb Diaphram craked: Fixable?
04 Dec 2008 18:08
I wondered the same thing, I thought about the RTV on it but I was afraid it would get sucked into the carbs. I just went to a local salvage and bought one. It was 50 bucks for just one. Kinda expensive but I couldn't find any other any cheaper. Then I didn't have to worry about anything.
81 XS 400 Cafe Project
82 Seca 400
83 KZ 750 LTD
83 KZ 750 Hardtail
98 YZF 600R gone
OKC, OK
82 Seca 400
83 KZ 750 LTD
83 KZ 750 Hardtail
98 YZF 600R gone
OKC, OK
- bountyhunter
04 Dec 2008 21:56
kzkx wrote:
problem with a 29 year old bike is I will be getting another 29 year old rubber piece at the salvage.
I found the OEM part at Babbittsonline for $75 each, don't know if it is actually available or not. I'll know soon.....
- Mcdroid
- Gone Kwackers
05 Dec 2008 05:44
George of
has mastered some repairs of torn diaphragms...contact him directly for the secret technique...also see the following link for new diaphragms:)
www.nrp-carbs.co.uk/index.htm
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- timebomb33
05 Dec 2008 05:52
i've different procedures over the years and i've never found any that really were acceptable so i won't even try them on customer carb's anymore it's not worth the frustration,i might if the diapraghm cannot be found but otherwise i just buy new.
I THINK MY POWERBAND BROKE
- JMKZHI
Last edit: 31 Dec 2008 15:45 by JMKZHI.
- bountyhunter
Re: Carb Diaphragm cracked: Fixable?
05 Dec 2008 16:01
So... I took the thing back out and gave it a really good eyeball and found out it doesn't have a hole..... it has three holes.
And the one on the other side has TWO holes......
Those little suckers are hard to see.
I am going to try the method of sealing it with probond urethane glue as suggested in the PM. I also ordered new ones but have no idea if Kawi still sells them.
- bountyhunter
05 Dec 2008 16:07
Mcdroid wrote:
Thanks for the link.
Is it correct that I have to send them the slides in the UK and they put the diaphragms on and ship them back?
George of www.wgcarbs.com has mastered some repairs of torn diaphragms...contact him directly for the secret technique...also see the following link for new diaphragms:)
- RonKZ650
05 Dec 2008 16:08
It looks like the diaphram is only used on the KZ750 twin, so things are not looking promising for getting new ones though Kawasaki
- bountyhunter
05 Dec 2008 21:09 - 05 Dec 2008 21:10
RonKZ650 wrote:
The crackhead at the counter of the local Kawi dealer said they showed up as available, but he could be full of crap as usual......
BTW, the one I need is the:
16028-1001
16028-1001
Last edit: 05 Dec 2008 21:10 by bountyhunter.
- H2RICK
- Is this a fun bike, or what!!!
07 Dec 2008 19:11
I've used Marine GOOP on carb diaphragms to repair holes.
Cracks are another story. At this stage you've got nothing to lose except for the cost of the tube of GOOP. I would recommend cleaning the diaphragm around the crack thoroughly with some isopropyl alcohol before applying the GOOP. Use as little GOOP as possible to do the job, smearing it along the crack and working it through to the other side and smearing it on the other side as well. Let it cure in a warm place for AT LEAST 24 HOURS before reassembling everything.
Let everyone know which method you're using and how it all turns out.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- bountyhunter
07 Dec 2008 21:20 - 07 Dec 2008 21:44
H2RICK wrote:
Substitute "probond" for "GOOP" in the paragraph above and that's what I did Friday. I reassembled it today and it seems to be working fine. I have no idea how long, but I suppose I can do it as required. The probond stuff seems well suited for the task. It expands as it cures, so use the minimum to get coverage. You definitely need to clean first, because the first time I didn't and it did not stick well. I pulled off the first glue remnants and then cleaned the edges of the slit with a Q-tip wet with acetone and did the gluing over. The second time seemed to stick well.
I have not been able to buy new slides or find anybody with used ones I could send out for new rubbers.
Last edit: 07 Dec 2008 21:44 by bountyhunter.
