Professional porting
- wireman
Re: Professional porting
12 Oct 2006 18:56
steell wrote:
The flyback circuit is built into the MicroSquirt (along with dual coil drivers) and no add on board is needed. The MicroSquirt was specifically designed for motorcycle use.
- solomrus
13 Oct 2006 07:27
i need to re-read the micro info again.
i seem to recall that it wasn't going to support multiple coils... hence why i ruled it out for a kz app.
that changes things.
--r
--r
198o kz1ooo Bravo Four
- larrycavan
13 Oct 2006 15:14
Double check the website to be certain. If you discover that it won't work, please let me know because I'm counting on that little box to fit my streetfighter project. It just makes everything that much nicer if the DFI and ignition are all in one box and tunable with software...
Larry C
Larry C
- steell
- larrycavan
13 Oct 2006 17:21
First....I apologize for getting this thread off topic. I do want to reply to this so we can hopefully clear up a couple of things.
Any future posts I make on FI will be in the appropriate FI thread.
According to what I'm reading, the microsquirt will only handle 1 low imped. injector per bank. Looking at the wiring on www.microsquirt.info , I've come to the conclusion that there are 2 injector banks [is that correct?]
Also, isn't the flyback board required if you're using low imped. injectors?
Does this effectively mean that if the micro includes the flyback board and if there are only 2 injector banks, then the allowed number of low imped. injectors would be 2?
I clicked on the link for resellers and there are several listed. Does anyone have experience with any of the listed resellers?
Is there a particular reseller that has good motorcycle setup experience with the product?
Just want to get all my ducks in a row before I try to order anything...
Thanks in advance
Larry C.
Thanks in advance
Larry C.
- steell
13 Oct 2006 21:56
larrycavan wrote:
There are no add-on boards for microSquirt, there simply is no room in the case for them.
I really need to get off my butt and get the GPz750 finished so I can install my MS on it, I have MegaSquirt 1, and I still have to order the WB (LC-1).
www.diyautotune.com/catalog/index.php
That's the way I read it also, you would need to use one resister per injector to use more than one low impedance injector per bank (2 banks).According to what I'm reading, the microsquirt will only handle 1 low imped. injector per bank. Looking at the wiring on www.microsquirt.info , I've come to the conclusion that there are 2 injector banks [is that correct?]
I was mistaken when I said that the MicroSquirt included the flyback circuitry.Does this effectively mean that if the micro includes the flyback board and if there are only 2 injector banks, then the allowed number of low imped. injectors would be 2?
I am familiar with most of them, and I don't recall any of them making bike related posts. I deal with DIYautotune, and have been very satisfied.I clicked on the link for resellers and there are several listed. Does anyone have experience with any of the listed resellers?
Not that I'm aware of, but there is an active forum, and many have done bikes (and lawnmowers/snowmobiles/etc)Is there a particular reseller that has good motorcycle setup experience with the product?
- larrycavan
14 Oct 2006 06:31
On EBAY this morning. Search Kawasaki Fuel Injection. There's a rack of TB's for sale.
- testarossa
11 Apr 2011 12:20
Lots of good info in this older thread. Posting here so I can find it again.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- Kraz1
11 Apr 2011 15:11 - 11 Apr 2011 15:12testarossa wrote: Lots of good info in this older thread. Posting here so I can find it again.
Here ya go.
Click--->[size=12pt] Basics [/size]
Click--->[size=14pt] Strategy [/size]
Click--->[size=16pt] Delivery [/size]
Last edit: 11 Apr 2011 15:12 by Kraz1.
- Kraz1
13 Apr 2011 02:41This will work for Nads.com also, I missed his post being removed today.
- vonbagh
23 Apr 2011 06:19 - 23 Apr 2011 09:44
I have read this topic many many times, and i dont understand everything, maybe someone can help. I have kz750-82 head which i want to port. This is what i have learnt. Intake valve is 34mm. so bowl area diameter should be 88%=> 29,92mm. Carbs are bs34 so runner diameter should match carb size. How do you calculate OPTIMAL cross section area diameter? And last question is, what kind of cfm numbers i should get -84 gpz750 head, when it is ported for street purpose?
Jos se ei tapa, niin se vituttaa.
Last edit: 23 Apr 2011 09:44 by vonbagh.
- wireman
23 Apr 2011 10:22
www.cavanaugh
racing heads.com B)
