Professional porting
- steell
Re: Professional porting
09 Oct 2006 21:35
larrycavan wrote:
If I see duplicate posts I delete them anyway, so just keep posting more info
If any kind of message box pops up, just click cancel, your post will still work.Why does this forum keep double posting on me? I have to go back and delete the duplicate post??? Never had that happen before...<br><br>Post edited by: larrycavan, at: 2006/10/10 00:10
- solomrus
10 Oct 2006 08:12
larry, the info that you are giving us here is priceless. please keep it coming.
you're discussing things that most head porting guru's will NOT talk about. that is, specific techniques and theory.
this is fantastic. thank you, thank you, thank you.
i do some porting on turbochargers to decrease spool time, and i understand now why some of the stuff i do to them works.
(i see the photo's now)
--r
Post edited by: solomrus, at: 2006/10/10 16:20
--r
198o kz1ooo Bravo Four
- Exitpupil
Re: THANKS
10 Oct 2006 12:19
You da man, Larry!
Post edited by: Exitpupil, at: 2006/10/10 15:47
Post edited by: Exitpupil, at: 2006/10/10 15:51
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- wireman
- larrycavan
Re: THANKS
10 Oct 2006 14:24
You guys are all welcome. Everyone may not jump in and start porting their heads but having information and concepts explained will at the very least, allow someone to make an informed decision.
When you lay down your money for hard parts, it's comforting to know you chose what you did with at least some confidence that you'll achieve your goal.
- larrycavan
10 Oct 2006 14:32
solomrus wrote:
Ported heads are perfect for turbo applications. Some people don't realize that. They think that just because the turbo is forcing the air into the port that the porting isn't important. It's quite the opposite though. Your turbo application can really benefit from good porting.
--r<br><br>Post edited by: solomrus, at: 2006/10/10 16:20
- GPzephyr
10 Oct 2006 15:19
Larry your info is great!
Im about to do a rebuild on my GPz750 turbo (ZX750E1)and am thinking of having a go at the cylinder head.
Im taking the engine out to 810cc, what would you reccomend regarding basic porting. Should I concentrate my efforts on the inlets or the exhaust?
Thanks
Chris
Thanks
Chris
1991, Zephyr 750. GPz750 turbo engine, 810cc, Garrett T25 turbo, GPz1100 throttle bodies, 310cc injectors, Power commander, Dyna coils, Lots more as well...
KB Saturn fitted with a stock GPz750 turbo engine. Loads to do on this project.
- larrycavan
10 Oct 2006 16:47
GPzephyr wrote:
Go easier on the exhaust side and focus more on the intake ports. Put the ECU into Race Mode, send the throttle bodies to Pogue Machine and have them pro flow them and install the adjustable fuel pressure regulator. Then grind the staking off the waste gate adjustment rod and give it some boost.
Pogue's throttle body bore treatment is and excellent mod for that bike. I can get their phone number if you like. They're in Oklahoma and still will perform the mod. I spoke with them about 2 months ago.
I have all the info on the wiring harness mod to put the ECU into race mode.
Thanks
Chris
- larrycavan
10 Oct 2006 17:36
Calculating Average Port Cross Sectional Area
a) measure the length of the roof of the port from the edge of the port entrance to the 45* cut in the valve seat...write down the measurement[roof]
b) repeat the process but measure the floor...write down the measurment [floor]
c) measure the port volume in cc with a burette...write down the measurement [volume]
Use these formulas to determine Avg. CSA for the port.
Roof - Floor / 2 = Port Avg Length
Volume / 16.387)/ Port Avg Length = AVG CSA
Port_Velocity = ( CFM * 2.4 ) / Cross-Sectional_Area
Keep in mind that calculated velocities are precisely that "calculated". Port shape can dramatically influence those calculations, thefore, a pitot tube and flowbench are the best way to measure local velocities.
- wireman
10 Oct 2006 19:17
larrycavan wrote:
:woohoo: :woohoo: sid pogue is still around?ive asked people on here but nobody else acts like theyve ever heard of him!i used to spend a lot of money through him years ago,is he still in oklahoma city ?GPzephyr wrote:Larry your info is great!
Thanks
Chris
- APE Jay
- larrycavan
11 Oct 2006 02:27
The younger crowd probably never heard of Sid. There's not much info on him on the Internet. We used to send him quite a bit of TB work back in the mid 80's. They know their stuff and give you straight talk. I always respected Sid for that...still do.
