1200 cc speed knocking??
  • martijn
  • martijn's Avatar Topic Author
18 Jul 2006 02:05
#62803
started up my standard KZ900 bored to 1200cc and it made quite some noise. Especially under load it's I think , knocking. Is that possible??? or do I have to use higher octane gas??
As mentioned everything is standard except 1200 cc
thanks
Martijn
  • wiredgeorge
  • wiredgeorge's Avatar
Re: 1200 cc speed knocking??
18 Jul 2006 05:47
#62831
What compression pistons are you using?
  • wireman
  • wireman's Avatar
18 Jul 2006 06:07
#62840
have you checked your timing?;)
  • trippivot
  • trippivot's Avatar
18 Jul 2006 06:23
#62847
carbon build up on the piston top in the summertime heat
will make your bike knock and ping big time
run a simple decarbon technique to get the big build up off of the piston crown it may help
  • martijn
18 Jul 2006 07:38
#62871
The combustionchambers are clean and there are brand new valves in it. The piston are normale ones (not with higd cams) compression is 10.25
  • wireman
  • wireman's Avatar
18 Jul 2006 10:18
#62904
yeah thats an old air cooled engine,if its hot outside it could be a problem.they are more tempermental than water cooled engines.try some 89-91 or maybe retard timing a little bit,but not too much or it will run hot.;) goodluck,happy wrenching!
  • wireman
  • wireman's Avatar
18 Jul 2006 11:39
#62923
i just noticed your carb post says something like 12.25:1 which pistons do you have?:whistle:
  • martijn
18 Jul 2006 23:40
#63085
I found the problem for the pinging/knocking. Apparently the camchain was ratching one tootht of the intake cam, caused almost valve bounce. Happend when doing some maintenance, putting the bike away for a month and wasn't paying any attention to it.
Tonight another try!!!
Thanks for you replies
Martijn
  • wireman
  • wireman's Avatar
18 Jul 2006 23:50
#63087
any damage?:S
  • martijn
22 Jul 2006 01:31
#63828
No damage. Now I'm struggeling to keep it running at idle speed. I retarded the ignition and under load at 2000 up to 3500 its still knocking. I'll try tonight a higher octane gas.
martijn
  • martijn
24 Jul 2006 13:16
#64299
I thought I had fixed it but it's still knocking. It's now running on high octane gas. Can anyone tell if a KZ1000 bored to 1200 cc with allother parts standard (except 4 into 1) can run normally without knocking??? compression is about 160-170 PSI!!
Martijn:angry:
  • KawasakiJockey
  • KawasakiJockey's Avatar
24 Jul 2006 16:28
#64344
How high of octane? 93 at the pump wont do.
