How big can 750-4 go?
- daveyg
Re: How big can 750-4 go?
13 Sep 2018 21:26
So the gpz750 crank and rods will swap right over to the kz750?
- zukdave
14 Sep 2018 18:16
The pre 83 Gpz 750 is a KZ the 83 and up is a ZX the GPz turbo used KZ650 cams and the rod's had 18 mm wrist pins.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: KZB2 650, daveyg
- daveyg
14 Sep 2018 22:58
So the turbo/650 cams are better than the KZ750 cams, and the turbo rods are stronger than the KZ/pre-83 rods?
- darlington
- S. Darlington
17 Sep 2018 09:58
I'm pretty sure the small end of the reg KZ gpz 750 are 15mm and the turbo is 16mm and so would need to be bored out 1mm to use KZ 1000 pistons. 18mm small end con rods are reserved for the 1983-4 GPZ 1100 motors only.
Keeping the good times rolling since 1982. Helping people with parts ,technical support and service of the 70's 80's Kawasakis in Eastern Ontario. Building roadrace bikes for individuals involved in Vintage Road Racing in the eastern Ontario region.
The following user(s) said Thank You: daveyg
- zukdave
17 Sep 2018 16:29
You are correct I was mistaken na is 15 and turbo is 16
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Nebr_Rex
17 Sep 2018 17:17darlington wrote: . 18mm small end con rods are reserved for the 1983-4 GPZ 1100 motors only.
You forgot about the KZ1100 LTD.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- daveyg
18 Sep 2018 19:21
Does it actually need a bigger wrist pin? Has anybody ever broken a wrist pin?
- daveyg
21 Sep 2018 16:19
Well my 3d printer only made one piston, missed the note that I needed 4 pieces. But the first came out fantastic! Can’t wait to get the rest back so I can get to casting! Also got some parts back for my next psychotic idea! Take a look!
- M1zore
02 Nov 2018 17:48
Please tell me you're gonna finish this. I would love to see a video of this running.
1981 KZ750H2 LTD, 1981 KZ750H2 LTD full vetter touring
- undiablo
03 Nov 2018 05:39
Following!!!
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- daveyg
12 Nov 2018 11:43
Well, I sold the chopper rolling chassis that I was going to put this Frankenstein engine into, but I kept the engine. Maybe it’ll go into my 93 zx6r chassis... or maybe I’ll build a small one or two person sand rail around it... would love to build a road vehicle trike (one wheel in rear, two up front) but doubt I could fabricate something they’d let me register in my dickhead state. I got all the 3d printed piston blanks back now, just kinda stalled as I’m working on getting my snowmobiles ready for the next season of fun. Before the snow flies here. Lots of work to put into my sled as I folded the front suspension in half when I hit a railroad track last spring but it’ll get ready sometime in the next couple weeks then I can get back on the crazy KZ engine.
- M1zore
07 Aug 2019 05:32
Hey DaveyG, I'm still interested. Have you had anymore break through on this projects or planned things for this year?
