  • Page:
  • 1
  • 2
Cam chain broke. Where do I go from here? 21 May 2018 14:41 #783794
  • Kaz
  • Kaz's Avatar Topic Author
  • Thank you received: 0
I have an kz750 twin. It wasn’t turning over so I took off the valve cover. There was no tension in the chain, I pulled on it and the chain came off and showed a broken link. Looks like I have a lot of work ahead.
I was considering putting a new chain on it but that seems like quite a bit of work. Before I get too deep into this project I wanted to ask if there is a guide / checklist for other areas to look while I have the engine out of the bike.
I also don’t want to spend thousands of dollars to find out I skipped a step and I have a paperweight.
Ive been searching online and there are not many resources for the twin.
Any help would be appreciated
Last edit: by Kaz. Reason: Attachment didn’t attach
Cam chain broke. Where do I go from here? 21 May 2018 14:51 #783795
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Thank you received: 1994
Sorry to hear of your misfortune.
No cost to tear it down and check motor over as long as you have a factory service manual.
Follow the steps. Keep all parts organized.
Check each over for damage.
Post lots of pictures for us to help.
Then make a shopping list of what needs to be done.
Cam chain broke. Where do I go from here? 21 May 2018 14:53 #783796
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2721
What is the history of the bike? Did you just buy it? If so the broken chain may have occured while riding and now there is carnage inside the engine including bent valves among other things. I think you are looking at a full engine teardown to fix the bike right.
Cam chain broke. Where do I go from here? 21 May 2018 15:49 #783801
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1929
Sorry to hear of your worst case scenario.
You have to pull the head first to check for bend valves. Later you have to split the engine case to renew the cam chain. Take of the oil pan first for cleaning and removing the broken cam chain parts.
Long story short, you have to remove the engine out of the frame for a better access to all parts.
A service manual is necessary for a beginner and engine a rebuild.
We will guide you to the rebuild process.
kzrider.com/modules/ServiceManuals/Kawas...l%20KZ750%20Twin.pdf
Last edit: by Scirocco.
Cam chain broke. Where do I go from here? 21 May 2018 16:40 #783804
  • Kaz
He bike wasnt running when I bought it. I thought it would be a carb issue. Once i got those off i saw the valves werent moving and now Im in my current predicament.
While i have the head and case off, are their gaskets or other parts that should be replaced. I would hate to do the work and skip a component
Last edit: by Kaz.
Cam chain broke. Where do I go from here? 21 May 2018 17:16 #783805
  • Nessism
  • Nessism's Avatar
  • Away
You can see all the various parts, including gaskets and seals, by looking at the parts fishe...www.partzilla.com/
I strongly advise toward OEM gaskets and seals where ever possible. Sometimes you can find good deals on OEM parts via ebay so you may want to check ebay once you find the part numbers you need. You should also get a real Kawasaki service manual. Not a clymers or Haynes. Money well spent.
Cam chain broke. Where do I go from here? 21 May 2018 17:42 #783807
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
  • Thank you received: 55
Might check You Tube. Sometimes there are good vids on how to do something before going into it.
Blue 1975 Z1B
Red 2009 Concours 14
Last edit: by Z1Driver.
Cam chain broke. Where do I go from here? 21 May 2018 20:01 #783818
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Maybe post your general location so we can keep a lookout for any possible used 750 twin motors available. They are not very common, but do come up once in awhile.
Cam chain broke. Where do I go from here? 21 May 2018 20:40 #783819
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2649
Well you can look at it this way, once you've gone through it, you'll have that certain satisfaction in knowing what's happening in between your legs. B)
THEN YOU CAN RIDE THE PISS OUT OF IT. :woohoo:
Cam chain broke. Where do I go from here? 22 May 2018 12:18 #783841
  • Kaz
I’m in the Seattle area.
Is there a recommendation for an engine stand?
I watched an old school Kawasaki repair video-
Am I going to need to remove the transmission/ clutch to get to the crank?
I found the part number on partzilla, 92057, and checked eBay for the same part number. I found a few auctions selling that part number but it was listed for other models:
rover.ebay.com/rover/0/0/0?mpre=https%3A...2Fitm%2F132242337451
www.partzilla.com/catalog/kawasaki/motor...afts-chain-tensioner
Any thoughts on that eBay auction
Last edit: by Kaz.
Cam chain broke. Where do I go from here? 22 May 2018 14:11 #783843
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
First download and read the manual before you buy any parts.
Pull the engine out of the frame, made a list of tools you need to do a engine overhaul.
Remove and disassemble the head and look for bent valves and/or piston dome damages.
Do small steps and post your progress and findings with some pics.
If the replacement parts list goes to long a replacement engine would be cheaper!!!!
Cam chain broke. Where do I go from here? 22 May 2018 19:21 #783851
  • loudhvx
  • loudhvx's Avatar
Too bad this one is not closer to you. I think it's a twin. If it's a '77 it must be.
So they are out there.
milwaukee.craigslist.org/mcy/d/rare-barn...cles/6565802917.html
  • Page:
  • 1
  • 2
