Cams
- roy-b-boy-b
Cams
01 May 2012 13:35 - 01 May 2012 22:21
Has anyone ever heard of a cam with 0.465 lift. That is the best guess I can get out of the cams I removed from the mystery engine. Roy
Last edit: 01 May 2012 22:21 by roy-b-boy-b.
- roy-b-boy-b
- dbsuperbiker
Re: Cams
01 May 2012 22:11
remove a zero---.465 inches is a plausible lift measurement for a set of very wild KZ1000 cams.
- roy-b-boy-b
Re: Cams
01 May 2012 22:22
Thanks, I just never seen the lift advertised. Roy
- racer54
Re: Cams
01 May 2012 22:55
A couple cam makers list that lift...
Megacycle lists 2 versions.....470-85 and 470-x15
470-85 .465 lift 270* dur. 108* l/c
470-x15 .465 lift 264* dur. 108*/110* l/c
Cam Motion......Z9 .465 lift 274* dur. at .050 lobe center 110*
- z1kzonly
Re: Cams
01 May 2012 23:54
Hey Roy, don't forget that the base circle on stock cams is about.962".
So when you just roll the mic or calipers over the lobe to get the highest measurement
does not mean the gross lift. You have to subtract something?
Let the Machine shop Head guys tell you.
Do you have a set of stock cams layin around to compare?
I looked at some stock used cams. there total measurements were about 1.418" -1.420"
across the lobes.
Did the head holding them cams have machined relief clearence spots on top by the lifter buckets?
Was it using shim under buckets?
across the lobes.
- APE Jay
Re: Cams
02 May 2012 03:14
Cans of that lift usually have a 1.00" base circle. Stock is 1.110"
- roy-b-boy-b
Re: Cams
02 May 2012 06:31 - 02 May 2012 06:33
I measured the lobes and subtracted the base circle. And yes the head was clearanced.
Thanks racer, I am just trying to nail down who made these cams.
Thanks Jay, I guess I could put all these parts in the lay down frame I have and just look at it and make noise at meets !
It was suppose to be Mike Brusso's bike!
Last edit: 02 May 2012 06:33 by roy-b-boy-b.
Re: Cams
02 May 2012 07:32 - 02 May 2012 07:33Converted from shim-over-bucket to shim-under-bucket.
Last edit: 02 May 2012 07:33 by Patton.
- roy-b-boy-b
Re: Cams
02 May 2012 07:55
I will have the head apart this morning. I don't think it has stock springs in it. :S
I am going to sell the whole package together. Roy
- roy-b-boy-b
- DoubleDub
Re: Cams
02 May 2012 09:45
I'd have to have get mine in front of me, but it looks like the 650/750 parts at a glance...
