Removing Camshaft Sprockets
  • notaduc
  • notaduc's Avatar
Re: Removing Camshaft Sprockets
28 Feb 2012 13:36
#506838
baldy110 wrote: I use an old cam chain, wrap it around the sprocket and tight the ends of the chain in a vise. I believe Kawasaki used some sor tof locking agent on the bolts when they assembled them. I ahve had a few that were on really tight.
+1
1980 (mostly) KZ1000
  • KZB2 650
  • KZB2 650's Avatar
28 Feb 2012 20:38
#506903
Should blue or red locktite be used on re assembly? And do you use the 36 link set up still(between the arrows) for the cam chain timing even though switching to the KZ750 cam with the stock kz650 sprokets?
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • DoubleDub
  • DoubleDub's Avatar Topic Author
28 Feb 2012 20:40
#506904
Personally, my thoughts are yes and yes. Timing shouldn't be any different, I don't think - I can compare timing marks between the two cams. Locktite wouldn't hurt, although I'm not sure which would be better - would tend to think the lower strength would be better.
