Tach Cable
- DaddyJama
Tach Cable
22 Jan 2012 23:22
so i had friends over and i fired up the bike..
to my suprise, the tach cable had come out of the head? so now it's hanging loose. the rubber parts comes down and there is a coil of wire that comes out of it?
How does this attach, is there something loose in the engine now that i have to worry about?
Im not really sure how it connects or pics up engine speed, maybe an expanatino of that would help clarify..??
82 kz440
82 kz440
2005 636 - track bike
1982 kz440ltd - new toy;)
- MFolks
Re: Tach Cable
22 Jan 2012 23:39
The tachometer cable usually is connected to the head by a retaing screw.Some engines have a different way to attach the cable. If your cable has come apart, it might be easier to buy a new one.
There is probably a worm machined on the exhaust cam the tach cable drive engages, making the tach indicate when the engine turns.
I'd suggest replacing any of the rubber seals the tach cable goes through as they get dry & crack, letting oil make a mess of the front of the engine
The following user(s) said Thank You: DaddyJama
- DaddyJama
Re: Tach Cable
23 Jan 2012 00:41
heres a couple of pictures of what's left..
i did google tach cables and they seem pretty simple. Take a look at what's hanging, could there be anything left floatig instide?
- MFolks
Re: Tach Cable
23 Jan 2012 00:47
The part that's still on the engine has a piece of the tach cable in it. Unscrew the knurled nut from the engine and see if the broken piece of the cable goes with it. A new cable should fit right on the engine using th knurled nut. See if the oil seals are gone or worn out inside the nut.
Re: Tach Cable
23 Jan 2012 01:02
Your cable is shot. You need to buy a new one and install it by removing the 2 knurled nuts (one at the tach & one at the engine). When you get the new cable it will be obvious how to replace it. Also, lubricate the cable before installing it. Ed
- DaddyJama
Re: Tach Cable
25 Jan 2012 00:48
thanx all.. new tach cable on the way..
- DaddyJama
Re: Tach Cable
28 Jan 2012 02:28
that was probably one fo the easiest fixes i've done...
also the original owner said the speedo did not work..
so while i was monkeying around with the tach i checked the speedo, and the speedo was just loose.. so i plugged it in and it worked fine;) also took a ride to day..
