power loss/bogging/hesitation in 4th and 5th gear
- danno8852
Re: power loss/bogging/hesitation in 4th and 5th gear
31 Oct 2011 08:54
The battery is brand new. I have no info on if the carbs were jetted for the elevation/climate. I bought the bike in Lowell MA and live on the south shore of Massachusetts. I will have to look at the spark plugs again to be more accurate later this week but I remember last time I checked (2 weeks ago), the ground straps were a greyish color with little if no carbon. I do remember pulling the plug out of cylinder #1 yesterday and the base ring was black and the ground strap was a bit darker compared to #2.
- danno8852
03 Nov 2011 21:41
So I have made some progress. I lubed up the pivot points on the andvancer and nothing. I then bought a mulitmeter and decided to test the coils. The primary resistance is fine on both coils. I then checked the secondary and one was 22.5 ohms, the other 22.8 ohms. The manual says the secondary should be between 12-18 ohms. Could the higher reading contribute to my issue? Also noted was that my spark plug wire connections from wire to caps are a bit crappy. One in particular I had to tape to tighten the frayed insulation. Surprisingly after I did this the bike ran much better. It is bogging less in high gears, more responsive, accelerates faster, and sounds smoother. I wouldn't say that it is 100% yet. I will buy some new wires and hoping it will be back to 100%. The high reading on the secondary coil still worries me though.
- danno8852
04 Nov 2011 01:17
does anyone know if it is O.K. to use solid copper core spark plug wires with my electronic ignition? or do I need the suppression ones?
Last edit: 18 Feb 2013 18:18 by martin_csr.
- rcarver
04 Nov 2011 09:44
I have copper core wires on my bike, running a Dyna-S ignition, Dyna Green coils, and Dyna copper core wires.
1979 KZ650 SR (aka: Stella Blue)
- danno8852
04 Nov 2011 09:54
Thanks rcarver that's all the confirmation I need! And thanks Martin csr I'll do that in the meantime, thank you.
