aftermarket valve seals
  • gwolever
  • gwolever's Avatar Topic Author
10 Sep 2011 11:50
#475648
Hey guys. I was told that many people on here have had bad luck with aftermarket valve seals. I was planning on using the valve seals from my Vesrah full gasket kit I bought to replace the 30 year old stock seals.
Is this a bad idea? I know those seals are old, but maybe I shouldn't replace them if there wasn't an issue with them. I have the bike and engine all apart for restoration.
The kawasaki seals I found online are sold for almost $12 each, and I really didn't want to spend $100 for them all with ship/handling.
What do you guys think?
1982 KZ1000 CSR
  • Old Man Rock
  • Old Man Rock's Avatar
Re: aftermarket valve seals
10 Sep 2011 12:18
#475656
Stick with OEM seals, don't ask me how I learned this one... :blush:
Nor ask how much crap I had to take off Plumi for not listeneing to him and Larry about the valve seals I should have obtained... Again... :blush: :( :laugh:
Babbits on line, I found for $9 each... worth every dime.... No Smokey/leaky....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
10 Sep 2011 13:28
#475660
I was considering using the Viton equivalents once I got around to doing mine. How do these rate compared to the OEM in your opinion? Do you still recommend the OEM seals over the Viton. The only reason I was even considering the Viton was due to their high temperature characteristics. So I thought they would be superior. Your response will be greatly appreciated and help me avoid some possible greif.
Joe
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • Charlie650
  • Charlie650's Avatar
10 Sep 2011 13:49
#475663
Vesrah stem seals ARE OE seals.
They source them from the OE manufacturers in Japan. You can use any of their products with complete confidence.
1977 KZ650C1
1975 H1F 500 Triple
2005 ZX10R
Sheffield(ish) UK
10 Sep 2011 14:49
#475676
The following user(s) said Thank You: KZJOE900
  • DFIGPZ
  • DFIGPZ's Avatar
10 Sep 2011 16:09 - 10 Sep 2011 16:09
#475693
KZJOE900 wrote: I was considering using the Viton equivalents once I got around to doing mine. How do these rate compared to the OEM in your opinion? Do you still recommend the OEM seals over the Viton. The only reason I was even considering the Viton was due to their high temperature characteristics. So I thought they would be superior. Your response will be greatly appreciated and help me avoid some possible greif.
Joe
Joe
you are correct the viton is a better seal you would be good to use them.
1984 750 Turbo
Last edit: 10 Sep 2011 16:09 by DFIGPZ.
  • bountyhunter
  • bountyhunter's Avatar
12 Sep 2011 02:04 - 12 Sep 2011 02:05
#476066
VITON is way better material than rubber. If Kawi had used it originally I probably never would have had to do the first two head jobs.
Last edit: 12 Sep 2011 02:05 by bountyhunter.
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
12 Sep 2011 09:52 - 12 Sep 2011 09:53
#476102
I'm going to do mine over the winter and though the Viton is a higher temp seal I want to know has anyone here used them and for how long with what kind of results.
The reason I ask is I have been involved with lots of different seal materials in my line of work and had some in-depth training by a seal manufacturer on various materials and their benefits/issues. The one thing about fluorocarbon seals (Viton) is that they have an uncontrollable shrink rate when molded, in a nutshell that means that the you cannot fully anticipate each time you make the seal how much shrinkage it will have (we're talking thousands of an inch here so no it won't be half the size as the next one) so the manufacturers will make the mold slightly larger than the standard ones to try and offset this issue. Most of my experience with Viton versus Buna/Nitrile is that the Viton will be a bitch to get the ID over a shaft but the OD will be noticeably looser than the Buna/Nitrile. The other factor is that fluorocarbon seals don't have the wear of a lot of other materials so heat isn't the only consideration here.
That said, like all things it depends on the application so that is why I want to hear from some users of these seals. By the way that price is dirt cheap!
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
Last edit: 12 Sep 2011 09:53 by KZ_Rage.
  • T_Dub
  • T_Dub's Avatar
12 Sep 2011 10:24
#476104
Larry Cavanaugh told me to use OEM seals, so I did. Really don't have any experience, but whats an extra 60 or 70 bucks on an engine build? I'm pretty sure Z1E got them for me @ $7 or $8 a piece. These are not exactly something you'll be replacing again for another 30 years, so why not put the good ones in?
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • bountyhunter
12 Sep 2011 16:39 - 12 Sep 2011 16:43
#476167
What I read (no guarantees) is that a valve "seal" is a misnomer since it does not actually seal to the valve stem, it has to let a little oil get by. So, I am not sure how critical the hole diameter is as opposed to the age related death where the rubber gets hard and cracks leading to massive failure.
I could not use VITON at my last rebuild because they were not available yet. I also could not go OEM because they are no longer available for the 750 twins (at least, that's what the dealers told me at the time) so I went aftermarket rubber which I assume will have a short, unhappy life. OEM are surely better than aftermarket rubber, but I would go VITON if I had the option.
Last edit: 12 Sep 2011 16:43 by bountyhunter.
  • etbike3135
  • etbike3135's Avatar
12 Sep 2011 18:40
#476179
How many miles are you guys riding before the Veshra seals go bad?? I have used them several time and never had a problem yet???
1973 Kawasaki Z1
18 years in dragbikes
  • wireman
  • wireman's Avatar
12 Sep 2011 21:31
#476215
here comes the old chevy vs ford debate! :sick: :woohoo:
