aftermarket valve seals
- cavanaughracing
- Banned
Re: aftermarket valve seals
12 Sep 2011 21:39
FWIW
You have to watch the kit seals. Some of them are cheap junk. Veserah stuff is usually pretty good but not always.
I push valve seals on with my finger after applying some white assembly grease. The good ones don't deform and remain nice & pliable like and OEM seal. The junk ones oval out when pushed onto the guide.
The blue viton seals seem pretty good. They're nice and pliable like an OEM Kawasaki valve seal.
Larry C.
cavanaughracing.com
cavanaughracing.com
- gwolever
12 Sep 2011 23:00
Wow. Some good stuff here. Lots to think about. The Viton are sounding better and better...and not a bad price either.
1982 KZ1000 CSR
- elfmagic17
13 Sep 2011 00:19wireman wrote: here comes the old chevy vs ford debate! :sick: :woohoo:
Being a GM Tech for 10 Years And A Ford Tech for 1 and 1/4 Years I can tell you that Gm Quality is Superior, But Ford has a Far better diagnostic system, you walk around front and it tells you whats wrong......
Kenny Hicks
74 Honda CB550
74 Honda CB550
- bountyhunter
13 Sep 2011 02:22 - 13 Sep 2011 02:22Every set of seals so far have failed after about 9 - 10 years, miles did not seem to be relevant. It's the number of heating and cooling cycles that kills rubber. City riding (like mine) kills them in quicker mileage. I think the first set went 40k miles, second set went maybe 20k, and third set maybe 15k (I was riding less per year later in life).etbike3135 wrote: How many miles are you guys riding before the Veshra seals go bad?? I have used them several time and never had a problem yet???
Last edit: 13 Sep 2011 02:22 by bountyhunter.
