Hard to start when warm
  • P21
  • P21's Avatar Topic Author
Re: Hard to start when warm
24 Aug 2011 22:47
#471581
ok guys just did a quick test tonight. i did a clear tube test (fuel level)
now this was done ONLY on carb #1 piston #1
and the reading was about 1/2" down from base of carb sounds like its not enough fuel?
i will check manual on this (read up more)
maybe thats why when i gave here more throttle it started
Please give me some sight on this matter Thanks Guys
Kawasaki KZ 1000 Police (2002) P21
  • testarossa
  • testarossa's Avatar
24 Aug 2011 23:25
#471590
1/2" is way too low. Should be more like 1/8".
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • P21
27 Aug 2011 13:51
#472146
Attachment CARBFUELLEVEL8-27-11004.jpg not found
Attachment CARBFUELLEVEL8-27-11024.jpg not found
Attachment CARBFUELLEVEL8-27-11006.jpg not found
ok guys a little update
the fuel level where all over the place but i think i gotem dialed in now.
also checked compression all good without carbs on 155+
spark check all good
thanks guys for the help and keeping my old dog on the road
here is a picture of fuel levels
  • MFolks
  • MFolks's Avatar
27 Aug 2011 15:03
#472158
These can get hot & become intermittent:
Ohm Checking Pickup(Pulsing) Coils
The pickup coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of 2K, check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS. The 550’s,650’s & 750’s may be backwards to the Z1’s,Kz900’s,Kz1000’s & Kz1100’s.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S” electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6. Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
7.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
27 Aug 2011 17:26
#472180
My bike requires a 1/8th blip or so of throttle to start when shes hot. no choke or nothin, just hold the throttle a crack and press teh starter down. Sometimes on super hot days the starter will turn over what sounds like 4-5 revoltions, but she fires off evertime.
I like my low end fairly lean tuned on the carbs, and it contributes to this symptom. Tuning the mixture screws richer some can make a difference it it doesnt mess with the idle/off idle performance too much.
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • P21
05 Sep 2011 13:07
#474343
an up date
its all good now
man she fire off with a little blip of throttle now
smooth all thru low and high power band like its a new bike now
it was mostly the the low end giving me trouble but not no more with the correct fuel levels
and while i was taking carb off decided to replaced the rubber intake boots and air cleaner ones
now i am happy runs like champ now!!
thanks guys for all the help
now lets get some miles on
  • STUNTMAN STEVE
  • STUNTMAN STEVE's Avatar
11 Oct 2011 02:50
#482505
So do you have to keep it filled with gas during the tube test? Just started with my carbs last night, and not sure if im doing it right.
'84 gpz750 work in progress/ money pit
  • TeK9iNe
  • TeK9iNe's Avatar
12 Oct 2011 19:07
#482798
The fuel should be free flowing (pri), or prime mode selected on the vacuum style petcocks, or ON with teh regular on/off style.
The tube indicated the level in the bowl as it comes to a stop via the float valves.
Being close to spec is generally good enough, the most important thing is that the fuel heights are as close as possibly identical to eachother.
GOod luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
