Ball Hone Choices
  • Marneman
  • Marneman's Avatar Topic Author
Ball Hone Choices
06 Aug 2011 13:30
#467232
As I prepare to hone my cylinders for a re-ring, I see that there are several choices in grit and material for ball/flex hones. Is there a preferred grit or style for cylinder honing? Most I see are 320 grit.
Thanks!
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
  • testarossa
  • testarossa's Avatar
Re: Ball Hone Choices
06 Aug 2011 16:15
#467259
Did you get your rings yet? IIRC finish hone grit depends on the ring material. It seems that the ring manufacturer would have recommendations on what grit to use.
This link from Hastings' web site has some instructions: www.hastingsmfg.com/ServiceTips/cylinder_bore_refinishing.htm
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • wireman
  • wireman's Avatar
07 Aug 2011 01:03
#467390
get a real hone with stones on it B)
  • Marneman
07 Aug 2011 01:57
#467399
I have a three stone cylinder hone that I've had for years. Seems that everything I read on here indicates the use of ball hones. I'm curious if I would be good to go using my old school one. Apparently more research is needed.
I'm thinking the difference would be how out of round my cylinder walls are.
  • wireman
  • wireman's Avatar
07 Aug 2011 03:39
#467403
id say the 3 stones would leave a more consistant finish
  • wireman
  • wireman's Avatar
07 Aug 2011 03:48 - 07 Aug 2011 03:51
#467404
Attachment SetWidth460-sunnen-hone.JPG not found
This is the way every decent machine shop ive ever been to finishes a bore after boring,if you ever go to a machine shop and they want to finish hone your fresh cylinders with a ball hone id suggest grabbing your parts and running like hell! :laugh:
Last edit: 07 Aug 2011 03:51 by wireman.
  • testarossa
07 Aug 2011 05:07
#467406
Ok, here's my .02 on ball vs. stone hones. Are your cylinders round and cylindrical? Do you want to know? Do you want to build the motor right, or just feel like you did the right thing?
If you are going to measure the cylinders for size, roundness and cylindricity, then you already know the answers to the above questions and you are wanting to do the right thing. Stone hone, or ball hone will get you the same result if your cylinders are in spec for all three measurements.
If you haven't measured, aren't able to measure, or don't want to measure those three things, and want to make yourself feel good about the finished result, then get a ball hone.
The main difference is that the ball hone will follow any variance in a bore and put the cross hatch pattern on all surfaces. This doesn't tell you much about the condition of your bore. The stone hone won't follow dips, egg shaped bores, etc. If you make a few passes with a stone hone, and see places with the fresh cross hatch and others that haven't been touched, then you will know that your bore is not perfect. Some people don't want to know this and so choose a ball hone. Guess what? If the ball hone puts a cross hatch in a low spot, and the rings don't ever touch it, then it won't seal compression very well. Rings are round and they cope with taper fairly well, but cannot conform to variances in roundness. If your cylinder is out of round, they don't seal and that's it. If it's tapered, they flex too much and wear too fast, and if the cylinder is worn too big, then they simply don't have enough tension.
I used to work in a machine shop that supplied, direct ship replacement pistons to Endyne. We also made pistons, rods, piston and rod assemblies, and cylinder liners for GE for their Gemini Compressor line of modular, natural gas, pipeline compressors. We had a very large Sunnen power hone to finish the cylinder liners. Guess how many ball hones we ever used? ZERO!
Not saying that a ball hone won't put a good cross-hatch on a good cylinder, but it will put a good cross-hatch on an otherwise worn cylinder that a stone hone will not. If I were you, and I already had a 3 stone hone, I would use it.
2004 ZX-10R
Angola, IN
  • nads.com
  • nads.com's Avatar
07 Aug 2011 09:45
#467433
testarossa wrote: Ok, here's my .02 on ball vs. stone hones. Are your cylinders round and cylindrical? Do you want to know? Do you want to build the motor right, or just feel like you did the right thing?
cylindricity..:huh:
At that point I decide it was best just to use the Schwartz Modulator.
Don't play with your balls if you have 3 stones
  • Motor Head
  • Motor Head's Avatar
07 Aug 2011 09:51
#467436
Also with a 3 stone hone, there are the easy to find flex hone. This has a center pivot on the stone so it can freely follow a tapper. Then there are the 3 stone hones that will have fixed, or a linkage for the stones to keep them straight, no flexing. I bought my Sunnen hone in the 1970's, it has a linkage for keeping the stones straight. The ball hones are good for just de-glazing, where the bore is good and you just want a fresh crosshatch for proper seating. Also I would recommend the ball hones for two stroke cylinders as they will Chamfer the ports, which is a must with a two stroke. Or the rings will snag a port, disaster!
I also like the ball hones for de-glazing the small cast iron brake cylinders, we used to kit brakes in the old days before the Chinese cylinders hi the markets.
  • testarossa
07 Aug 2011 11:00
#467447
nads.com wrote: cylindricity..:huh:
Here you go Nads. Cylindricity explained. It's real man, it's real. Click the link if you are ready: Hope you don't get a nosebleed when you read this link.
You are always wanting the real knowledge, there it is. Expand your horizons and study Geometric Dimensioning and Tolerancing. I bet you don't find any references to Schwartz Modulators. Google is your friend.
2004 ZX-10R
Angola, IN
  • steell
  • steell's Avatar
07 Aug 2011 11:49 - 07 Aug 2011 11:49
#467455
I feel like I have stepped 30 years into the past.
Back in the old days (maybe 20 years or more) cylinder honing was done almost exclusively with rigid hones and honing stones which led to some problems such as rough cylinder surfaces. It used to be that the rings scrubbed or shaved off the peaks of rough material left by the rigid stones over time. You may have heard of breaking-in a cylinder. That's what this is.
For anyone that would like to be a little more up to date on cylinder refinishing, I recommend the following.
PlateauHoning
Cylinder bore surface texture analysis
plateau-honing-consider-ball-style
plateau_finish
In the case of the OP, he merely wants to use a Flex hone (aka ball hone) as a glaze breaker, and that's fine, nothing wrong with that at all.
Last edit: 07 Aug 2011 11:49 by steell.
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
07 Aug 2011 15:27 - 13 Feb 2012 18:08
#467505
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 18:08 by KZ250LTD.
