Why do you need to reset the cam chain tensioner?
- ipale
06 May 2011 15:48
I have read that you need to reset the cam chain tensioner after setting valve clearance on a KZ1100. I would like to understand why. As there is no mention of this in the manual section on setting the valve clearance.
- wireman
Re: Why do you need to reset the cam chain tensioner?
06 May 2011 16:03
if your bike is a j-series without the idler sprocket between the cam shafts you have a cam chain guide built into the bottem side of valve.
when you remove the valve cover the tensioner will automatically take the slack up which make it a pain in the ass to get the valve cover back on .
- ipale
06 May 2011 16:13
Thank you for the quick response.
Cheers!
Cheers!
- ELCouz
22 May 2011 13:37when you remove the valve cover the tensioner will automatically take the slack up which make it a pain in the ass to get the valve cover back on .
And if i recall correctly timing will be off by a few degrees... enough that i had engine knocking when I've forced the valve cover (noob mistake
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
