Tight spot on crankshaft
- nads.com
Re: Tight spot on crankshaft
26 Apr 2011 12:40 - 26 Apr 2011 12:48
Try taking out the crank and using a leather or rubber strap couple feet long. Place it over each bearing one at a time and pull down on each side of the strap (to load the bearing) and spin the bearing back and forth and round and round ( you can make up a song here too if you like) then maybe you could feel the diff. I'm thinking rust from heating and cooling the garage. The ball bearings are going to be in diff. spots all time so that could explain the intermittent bind. I just took out a crank and its going in a plastic tub submerged in oil. Old KawMan has a pic on his website of crankstorage.
I polagize for sounding somewhat sane
cuz we all know
IM NOT
I'm thinkin like, "the little tiny bearing goes round and round, so early in the morning, sometimes it sticks and binds alot, maybe it's rust and maybe it's not , so early in the morning". :woohoo:
cuz we all know
IM NOT
Last edit: 26 Apr 2011 12:48 by nads.com.
- Kidkawie
- I bleed premix
26 Apr 2011 13:00
This may be a dumb question but you do have oil on the bearings and crank journals, right?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- baldy110
08 May 2011 22:50
Ok for you guys who think you cannot bend a crank by letting it lay on the floor.
After a lot of measuring I discovered my crank was not straight. It was off by a lot. Now this came from a good running engine and the only thing I did was store it in a box on the floor for about 3 years. Yes I oiled up everything prior to storing it.
I installed a known good one and the tight spot went away. The next time I store a crank I will store in an old engine case.
- wireman
09 May 2011 00:27
you could build a rack to mount on a wall or bench that would hang the crank by its end,ive seen lots of car cranks hung this way under harmonic balancer over the years
- Kidkawie
- I bleed premix
09 May 2011 10:49baldy110 wrote: Yes I oiled up everything prior to storing it.
I meant, was the crank was oiled when you INSTALLED it in the block? Or were you spinning a dry crank around in dry bearings?
You can make a holder using 2x's cutting some V shapes out of the ends.
1975 Z1 900
2004 KX125
2004 KX125
