Engine cuts out at 90
  • TexasKZ
  • TexasKZ's Avatar
Re: Engine cuts out at 90
04 Jan 2011 10:32
#420036
  • KZCool
  • KZCool's Avatar Topic Author
08 Jan 2011 20:20
#420925
SO I am taking everything apart for my next modification overhal and found that one of my carbs was set at a leaner setting on the main jets. Im thinking that may have been the reason the cylinder was cuting out at such high speeds. I wont be able to check until I get everything done though and thats a suicide shifter with clutch and hopefully a bobber seat and stack style pipes, all fabed up.
1976 KZ750 hardtail
  • KZCool
24 Mar 2011 17:38
#440174
I have gotten my bike back together and I was working with the timing. I advanced it as much as possible and it ran at idle a lot smoother, but then when I opened it up it got to 80 and the same thing happened. One of my cylinders cut out so I backed off, down shifted and held it at redline for a good 7 seconds. I hit 90 again no problem. I'm thinking my bike may very well have a limier in 5th gear. Any body have any clue.
1976 KZ750 hardtail
  • KZCool
04 Apr 2011 12:10
#442546
BUMP
1976 KZ750 hardtail
  • hocbj23
  • hocbj23's Avatar
04 Apr 2011 12:32
#442557
I dont think the 750 twin had a rev limiter unless a PO put one on it OR ur using gauges/wiring from another bike.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
04 Apr 2011 14:41
#442590
There is no limiter.
Whats the compression on the motor? Sounds like she is just running out of steam. Its always easier for the engine in lower gears.
Could also be a fuel/carb thing, check fuel height in bowls, and make sure the mains are large enough... have you correctly jetted bike for any mods???
Whats with advancing the ignition far as it can go.??? tryin to blow her up? what you mean far as can go?
Try stock settings for ignition.
Peace.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • KZCool
11 Apr 2011 11:29
#444049
Well I have a Dyna S ignition and the timning plate doesnt match up exactly for where the timing sensor needes to be. I cut the slotsw longer so i could advance it further and it runs a lot smoother now, and I bought new fuel filters finaly when i came accross a dealer and vualla 102 MPH : ) Im much hapier now and so is the bike. One of the filter must have been dirty because it was startign to cut out on the highway every few minutes. All better now though. Thanks for the help guys and sorry i didnt trythe filters ealier :P
1976 KZ750 hardtail
