How to remove broken stud that has broken bit inside?
  • saxjonz
  • saxjonz's Avatar Topic Author
  • KawboyZ
15 May 2008 19:22
#213898
Here is a good question. I took this bike to have a broken stud drilled out and the guy tells me that someone else had already tried to drill out this stud and must have broken a bit off inside. He said that I would need to take it to a machine shop where they would basically burn it out. He said I would have to remove the head or take the engine out to do this.:unsure:
Is there any trick to doing this without having to go through all of that?:(
I was looking forward to getting it done and riding it this weekend. I would greatly appreciate anyone's valuable feedback as I have never dealt with this before. I did read a post by Jeff at Z1 that said that those mac headers were good for this kind of trouble.
79 LTD B3
  • PLUMMEN
  • PLUMMEN's Avatar
Re: How to remove broken stud that has broken bit inside?
15 May 2008 20:17
#213909
is it an exhuast stud?can you use a harder slightly smaller left handed bit to turn it out?:(
  • KZErider
  • KZErider's Avatar
15 May 2008 20:48
#213918
Is it broken off flush or is some of the stud sticking out? Maybe (a big maybe) you could use a dremel cutting wheel to cut what's left of the stud out of the way so you can get a pair of vise grips on the bit.(?) Just a thought.
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
  • jdburke
  • jdburke's Avatar
15 May 2008 21:04
#213920
Back when freon was cheap, I was able to extract a couple of broken bolts, by freezing the broken bit and shattering it. A center punch in my air hammer worked nicely. Once the broken bit was out of the way I could remove the remains of the busted bolt.
John
1978 KZ 1000A2
N.E. Oklahoma
  • enormiss
  • enormiss's Avatar
16 May 2008 04:28
#213961
If you know of anyone with a welder I've removed many broken studs by welding a nut on the end.
Just removed a carb holder bolt that broke this way.
The heat also helps unstick it (probably why it broke originally).
Not sure if the broken bit already in there would hinder welding.
81 750 LTD
96 DR 350
94 DR 350
S. Jersey
  • saxjonz
  • KawboyZ
16 May 2008 07:12
#213982
The bolt broke off inside the hole and there must be about 3mm inside. The dremel sounds like a great idea. I read somewhere about a diamond drill bit attached to a dremel. That is is harder than the hardened drill bit so it would work for cutting out the drill bit. I have cutting wheels unfortunately nothing was sticking out. I tried to drill a hole but it wasn't happening.
79 LTD B3
  • BSKZ650
  • BSKZ650's Avatar
16 May 2008 08:41
#214002
diamond is not going to cut the steel, the only real option is to have a shop with a EDM burn it out, or try to break the bit out of the stud by hand, you will propbably make a mess out of it before it shatters since the stud is way softer than the drill, and chances are the guy who attempted to drill it out has made a mess to start with
77 ltd1000, current rider
76 kz900, just waiting
  • jordan
  • jordan's Avatar
16 May 2008 10:05
#214023
I like enormiss's idea. I had to use this method on about 6 exhaust studs on a 650 head. If there is still some stud coming out of the head this is the best method IMO.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • saxjonz
  • KawboyZ
16 May 2008 12:19
#214049
Only wish this were true but unfortuneately the stud broke off inside so I guess that rules out any chance of using that method.
So no diamond bit like I had read that would be a waste of time? I guess if I have nothing else to lose but pulling the head off and taking it in to the machine shop I might as well try it to see what happens.
79 LTD B3
  • KZErider
  • KZErider's Avatar
16 May 2008 15:30
#214074
Sorry you're having to do all that. With none of it sticking out, it sure reduces your options. I hope the machinist can fix it up for you. Good luck!
  • saxjonz
  • KawboyZ
16 May 2008 16:34
#214085
Well heck with it. I am going to try the idea of using a diamond drill bit and if it doesn't work then I guess I will pull the head but that seems like too much work when it doesn't need to come off until it needs to. The bike runs sweet doesn't smoke or nothin.
79 LTD B3
  • steell
  • steell's Avatar
16 May 2008 21:46
#214141
Use clay (modeling clay, play dough, etc) and build a pocket shaped dam around the hole, then mix up some alum and water into a thick slurry (thin enough to pour). Pour the alum slurry into the pocket you built up around the hole until the hole is filled. Let it sit overnight and see if there is anything left of the drill bit or the bolt. May have to do it twice to dissolve all the bolt.
Alum should be available where swimming pool supplies are sold.
Sounds crazy, don't it? It works and won't damage aluminum.
The following user(s) said Thank You: bluejacobs
