zinc plating?
  • wiredgeorge
  • wiredgeorge's Avatar Topic Author
zinc plating?
30 Dec 2008 13:13
#255397
I really need to do some small scale zinc plating. Many of the small parts that get bead blasted to remove rust on carb assemblies I work on require replating to make them look nice. I have been using another plating source and they have gotten really expensive. Anybody on KZrider do any zinc plating? Willing to share tips/tricks and describe what is needed to start doing the plating? I have seen a couple "kits" which consisted of a battery pack and a couple leads, some acid solution and a couple pieces of zinc plus a couple brushes and cleaning compound. I have seen more professional looking "regulators" used for plating. Not sure what I need to buy to get started.
  • Kawickrice
  • Kawickrice's Avatar
Re: zinc plating?
30 Dec 2008 13:35
#255406
Check out the Eastwood catalog. They sell a plating kit.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • wiredgeorge
Re: zinc plating?
30 Dec 2008 14:46
#255414
Yeah, I know. A couple of small batteries with leads, the zinc in bar stock, some sulfuric acid in solution and some cleaner with a brush. $70. I expect I could buy the same stuff at a hardware store for a bit less... was wondering if this level of stuff would be right. I couldn't view their video on the subject... Notice they didn't supply a tank?
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
Re: zinc plating?
30 Dec 2008 15:57
#255428
i found this hope it helps loads of info on the subject no video sorry i looked everywhere.
www.pfonline.com/articles/pfdbiddulph01.html
  • steell
  • steell's Avatar
Re: zinc plating?
30 Dec 2008 20:55
#255469
You might check out Caswell www.caswellplating.com/kits/zinc.htm
They have a pretty active forum there also.
  • H2RICK
  • H2RICK's Avatar
  • Is this a fun bike, or what!!!
Re: zinc plating?
31 Dec 2008 11:10
#255539
A buddy of mine has the Caswell kit and he's pretty happy with the quality of plating it does. He does say, though, that most of the work IS in the preparation of the pieces i.e. cleaning properly, filing/smooting the rough bits, etc.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
  • dman3998
  • dman3998's Avatar
Re: zinc plating?
01 Jan 2009 16:26
#255710
150 bucks for the small kit!, but that would do most of the little hardware parts on a major rebuild. The only other solution I can come up with is paint and that is not Original looking and comes off easy on bolt heads.
My only question is how long can the chemicals "hang" around?
like I get the kit and do a couple dozen parts then I don't need it for 6 months is everything toast and I have to buy new chemicals even though I hardly used them up?
Monday I think a call to Caswell is in order.
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
  • kawtoy
  • kawtoy's Avatar
Re: zinc plating?
02 Jan 2009 17:31
#255817
Eastwood video link. Looks like you have to hand polish everything after plating.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • arai59
  • arai59's Avatar
Re: zinc plating?
02 Jan 2009 18:37
#255825
George, there is a plating company close by my shop. He does a bucket of parts, bolts, etc. for like $50. Can't beat it. He does clear zinc and yellow zinc.
  • wiredgeorge
Re: zinc plating?
04 Jan 2009 14:05
#256153
The problem would be turning stuff around and keeping track of it. I think I will do this stuff in house. I have some things to do first before taking on plating but will get it done some time this spring. I will likely go with a Caswell kit.
  • Mellvis
  • Mellvis's Avatar
Re: zinc plating?
04 Jan 2009 19:23
#256204
My brother does zinc plating at home. He is a member here also, Dreamsofaz1r. If you would like, I'll have him contact you when I see him next time.
  • dman3998
  • dman3998's Avatar
Re: zinc plating?
04 Jan 2009 20:40
#256215
This is interesting, answers some of my questions.
www.medial.com/suzuki/zinc-plated/
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
