what to do??
  • jim_palmore
  • jim_palmore's Avatar Topic Author
what to do??
07 Sep 2008 20:53
#236061
well my bike is leaking oil from the front so I think its a head gasket. the problem is that it was my primary transportation so now I have to fix my pickup so it will smog.
I don't have the funds for both.and the way the economy is going I will be laidoff this winter so saving it and rebuilding it this winter is not an option. no funds and I will probibly have to go out of state to get a job (I drive truck and local work is real slow in the winter so I will go "over the road")
I'm tempted to part it out online but don't want to be stuck with a carcas that has parts that are un-needed.
I'm in the bike over 2k. its been an expensive education. I have it on craigslist but haven't gotten and bites.I don't know what to do..
ENJOY LIFE,, THIS IS NOT A DRESS REHEARSAL.
1991 KZ1000P FROM COPPER TO CHOPPER. MY BADASS BOBBER
  • PLUMMEN
  • PLUMMEN's Avatar
Re: what to do??
07 Sep 2008 21:11
#236066
clean the motor up really good first before condemming it.if it still runs good it could just be a valve cover gasket or tach drive,if all else fails try retorquing the head B)
  • jim_palmore
Re: what to do??
07 Sep 2008 21:26
#236073
I forgot to mention that there is oil in the right side pipes
  • PLUMMEN
  • PLUMMEN's Avatar
Re: what to do??
07 Sep 2008 21:31
#236074
could be leaking down from valve cover and working its way around exhuast flange,run compression test on it if your convinced its a head gasket.i start with simple stuff 1st though ;)
  • jim_palmore
Re: what to do??
08 Sep 2008 20:34
#236255
you think it could be the rings. thats the suggestion I got from a co worker.
got a quote of 1000 - 1200 to rebuild the motor.
what if I bought a set of 1075 jugs and pistons, did a valve job have wiredgeorge do the carbs. simple plan..
do able????
  • kawsakiman
  • kawsakiman's Avatar
Re: what to do??
08 Sep 2008 20:42
#236257
a upper half gasket set can be had for under $100.
clean it like plummen suggested and find the leak first before you make any rash decisions like parting her out.
  • N0NB
  • N0NB's Avatar
  • Blue handles better
Re: what to do??
09 Sep 2008 04:37
#236289
Whoa! Slow down a minute, Jim. You're halfway to the moon and haven't even fueled the rocket yet! :D
Identify the source of the leak. With oil a small leak--barely a pin hole--can create quite a mess. Take some pics and share them with the folks here.
Do a compression test as suggested. What do the spark plugs look like.
I think I'll move this to the Engine forum where the technically inclined folk will see it.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • Old Man Rock
  • Old Man Rock's Avatar
Re: what to do??
09 Sep 2008 05:47
#236294
I have to agree with everyone here on this Jim where notch it down for if you have no funds, rebuilding the motor, pistons, bore, valve job, carb rebuild for an oil leak isn't a cheap option.
For all this work, probably add another $1500 plus (piston kit alone is $500 then add $80 bore/hone per cylinder hole, pending your heads condition valve parts $270 plus labor $250, carb re-build $300 at which point it becomes harder to sell unless in immaculate condition for you now have $4k invested.
Sure, it would run real nice and most of us are doing just that but not our main transport and we are spending the cash.... This crap ain't cheap, expensive hobby.
Some questions to ask yourself and in troubleshooting your problem.
Find the source of the leak... If blown or worn gasket/s, then replace top/lower/valve gaskets as Steve mentioned. Hell, I purchased my bike (every friggin gasket on the bike) complete gasket set for $80...
Was the bike blowing smoke prior to the oil leak?
Where you hearing a pinging sound such as broken rings prior to the oil leak?
Did you have good acceleration prior to the oil leak?
What do the spark plugs look like, burnt, oily, melted etc...?
As Nate mentioned, what's the compression testing inform you?
Are your cylinder/head bolts tightened to spec?
And tightened in correct order...
As Plummen replied, is the exhaust bolts tightened to spec?
All in all, with some troubleshooting, 1 days time and some gaskets, you can most probably fix your leak for under $100...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Tony
  • Tony's Avatar
    Author
Re: what to do??
09 Sep 2008 07:50
#236316
49.68 from Z1E
  • jim_palmore
Re: what to do??
09 Sep 2008 20:06
#236441
my main thing is that I know I will get layed off this winter and possibly not be called back (down sizing) . I don't wanna get into a project and not have the money to fix it nor the time.
like I said earlier I drive truck so there is a good chance that I will have to go drive coast to coast. got 1.65 million miles of doing that for 15 years and its a hard place in the winter. ya can't stop because you get paid by the mile and 2 weeks of 35mph because of snow and ice sucks.. but enough boo hoo..
then as stated there is a point where ya gotta put the fork in and call it done. I'm in this free bike over 2k. I would love to be able to put 1500 in it and have the bike I want to ride for years to come. the best I can do now is try all the suggestions that have been submitted and hope to make it so I can sell it. I will be building another kz. this has been a really sweet bike and since I hate to be part of the herd , I will be sticking to kz's an be unique. will keep all advised of the outcome..
I do want to thank everyone for their advice. this is why I like this forum so much. good people helping each other out :) :)
  • bountyhunter
  • bountyhunter's Avatar
Re: what to do??
09 Sep 2008 21:54
#236457
That's where a leaky tach drive dumps the oil.
  • bountyhunter
Re: what to do??
09 Sep 2008 21:58
#236458
Unless the bike has 50k miles or was abused, I doubt it. Ring wear doesn't cause oil leaks, they reduce compression and cause oil smoke under acceleration. Get a compression gauge and check before making decisions.
That's actually a decent price if it includes parts and labor.
do able????
Unless there is significant cylinder wear, you might be able to simply do a cylinder hone to deglaze and install new rings. Do a head job and you should be good to go for maybe 40 - 50k more miles.
